Hi All,
I've got two original Z32s for sale with brand new plugs.
$500 ono
Apexi PowerFC BNR34 w/ hand controller
$800 ono
Located in Sydney! Perfect working condition and only removing because i've upgraded to the haltech platinum pro
Cheers
Gordon
https://www.sau.com.au/forums/topic/357918-z32-x2-apexi-powerfc-bnr34/
Hi Dan,
Thanks for the kind words :)
Jap_star, Ad's... Dont really want to seperate as you can see they're an original pair for a z32, but if you guys want i'll do it $220 posted to both of you? I'll provide you with a new plug as well
Cheers,
Gordon
