Hey guys took car out for a spin tonight and under full boost I get s spluttering sound and notice that I'm hitting 100% duty cycle around 2/3 of the time ?
Forged rb25det
Gt3582r @ 20 psi
Sard 550cc
Sard FPR (new)
Walbro 255 pump
Z32 afm
Power fc pro
https://www.sau.com.au/forums/topic/358384-spark-issues/
A 35R should be making a LOT more than 290rwkw @ 20psi. You'd expect around 340rwkw.
Clearly you have issues going on, probably a combination.
I suggest you go back to whoever tuned it and get it on the dyno to diagnose the problems. Could be a number of issues.
https://www.sau.com.au/forums/topic/358384-spark-issues/#findComment-5726227
Well maybe it's the fact my car was slipping on dyno and I've fitted new clutch on saturday and now it's getting all the power to the ground ? Shouldn't 555cc injectors support 350rwkw like everyone on forum states they can
https://www.sau.com.au/forums/topic/358384-spark-issues/#findComment-5726235
They will support 330-350rwkw. But who knows whats going on.
You've fitted an aftermarket reg, it could be set wrong.
Fuel pump might be having issues, fuel filter even
As for the power you might have exhaust restrictions, timing could be wrong
Who knows mate. I think there is more to your problem and it's not coil packs at this stage.
Either way you must take it and get it looked at on a dyno, see what the fuel pressure, AFR's, boost etc is all doing.
https://www.sau.com.au/forums/topic/358384-spark-issues/#findComment-5726238
  On 22/03/2011 at 1:42 PM, R31Nismoid said:
Especially with your threads the past month, certainly issues
I may be barking up the wrong tree here, but does it pain you to talk/type in a friendly/non-threatening tone?
Yes, your posts are very informative, but you almost always talk down to everyone who has less knowledge than you, sorry just pointing it out.
https://www.sau.com.au/forums/topic/358384-spark-issues/#findComment-5726252
Well no - it's still down on 50rwkw for the boost/setup you have.
So whilst you had bung plug, it doesn't explain the rest. Or why the plug was fouled in the first place.
I was stating a fact - It was totally neutral.
Have a look at his post history. He's had a number of issues with the car of late.
If stating fact is a non friendly tone, well stuffed if i know what your talking about.
https://www.sau.com.au/forums/topic/358384-spark-issues/#findComment-5726270
  On 22/03/2011 at 1:57 PM, gL3nJaMiN88 said:
And yeh she is running 44 psi is that ok?
That is the factory psi, since it is adjustable you may as well up it a little on your next tune to give your self more headroom and keep it safe.
  On 22/03/2011 at 2:22 PM, gL3nJaMiN88 said:
Yeh well I'm not sure maybe the fact im running a stock exhaust manifold and intake manifold ?
  On 22/03/2011 at 1:42 PM, gL3nJaMiN88 said:
Yeh I have a good exhaust setup 3.5 inch cat back and it's only a new FPR and pump , what fuel pressure is recomended ?
So judging by those 2 comments im assuming that you have factory manifold, dump, front dump and cat?
If so there is your problem, upgrade the dumps and cat first and see how it goes then do the manifold if needed.
https://www.sau.com.au/forums/topic/358384-spark-issues/#findComment-5731451
I agree with your post 1000% because you are CORRECT 74 thousand posts that would Drive me stoopid also he does not think he talks down to members but he prooves it in his reply to ohwell
ive just wasted another 5 minutes of my time Grrrrrr
https://www.sau.com.au/forums/topic/358384-spark-issues/#findComment-5733194
