  • Replies 89
It may be adjustable, but it most probably is not going to be as adjustable as you think. Remember, it still has the same spring in there.
A typical standard actuator might require 10mm of travel, and it may open at say 9psi and be fully open at 11 psi (for example).
Now if you compress the spring an extra 10mm by tweaking the control rod, it might then start to open at 11psi, and be fully open at 13psi.
But if you try to go higher you might find that the coils in that spring just go solid. It is not a very long spring you are playing around with. When the supplier sells you an adjustable wastegate actuator, it probably means you can adjust it exactly to the rated pressure, perhaps +/- 20% or something like that (guess ?)
You are not going to be able to set the boost anywhere from 5psi to 25psi, no way. You are going to have to use an air bleed system, or a proper boost controller to do that with a five pound actuator, or whatever.
I think the best feature of an external wastegate is you can easily change the spring, and/or fit an external pressure regulator that will give you fully adjustable boost. Every external gate I have ever seen comes with a pressure port on both sides of the diaphragm. The manufacturer also will have a wide range of springs available. You cannot do the same with the cheapie on turbo actuator, because the control rod end is open to atmosphere.
Anyway its about 100 more then the HKS one.
So the HKS ones are around $147 ??
But why adjust the rod for boost control when its easier to adjust the boost controller with the screwdriver??
Cause this 'may' get rid of the boost dropping off at the top end ??
Yepp, wouldn't give you as much adjustment as a bleeder, but if you only want 12 or 13psi it may give you a better result than buying a EBC a setting it at one setting and leaving it.
Just a thought..
J
I have an adjustable aftermarket acuator (garret i think) that I had adapted for my car. It is currently set at 15psi and holds it perfectly, no need for any EBC or bleed valves. I got it for a mates rate $200 exchange.
I think it holds 15psi to redline, I will check on the way home tonight :D
Adam
I'd like to wait a bit and see if anyone (SydneyKid in particular :D ) has had any experience with the GCG ones.
At the moment I can only go from what GCG have told me, which does sound good.
The last thing I want to do is arrange a group buy, then later find out there is a better option.
Zombie - I'm keen to see how yours goes (holds boost), and if you can find the make of it it'd be great :)
J
The HKS upgrade wastgate actuator, which will fit on our cars is approximatly 11,384 Yen, which equates to 135.762 AUD
Plus say 20-30 for postage. Adds up to under 160. Thats what im getting.
We could get a small group buy happening, it would only alter the price a little however savings would be in the shipping.
I'm just having a read on http://www.takakaira.com/performance/main.html about the HKS upgrade actuator.
it says 'boost pressure can be altered by expanding or retracting the actuator rod'
It doesn't say anything about an upgraded spring, BUT being HKS I wouldn't doubt if it has an upgraded spring. They show dyno graphs etc as well.
If the HKS one holds boost (upgraded spring) I think they would be the way to go....
J
I think when you order the part, u tell them what psi u want to hold. they sell the actuator that holds the desired boost level. Im not sure about them being interchangeable, but i know that BOOSTED on these forums upgraded his actuator to the HKS one and he can hold in the vicinity of 18-20psi, obvioulsy the turbo has been modded, but still retains r33 turbine
Interesting topic..
At the drags both last night and the week before it felt like my top end (5,800->6800rpm) was 'lacking', almost like the turbo was running out of puff. I got 2rismo to drive it and he straight away thought it was my standard wastegate not holding pressure. I thought i'd just be able to swap over to a high pressure spring but as mentioned above this doesn't appear to be the case.
Does anyone know what the standard wastegate can hold? Can these things 'wear out' over time? (my car is a '95). I'm only running standard ECU so I was thinking it was just in dire need of a thorough tune but after reading this thread and letting 2rismo drive my car (he did a 14.1 and a 14.2 which is equal to my PB) its got me thinking...
I've always been told by Dyno Operators that my car holds boost perfectly but the last time I was on a dyno was 6mths ago so maybe that has changed. I'm using a TurboXS Dual-Stage boost controller with a switch in the center console set to 7/12psi. I use 7psi for daily driving but want to use 12psi at the drags.
n00b.
Nothing like starting with the obvious first :D I've been meaning to reset my ECU after replacing the HKS Pod with the Stock Airbox + K&N Panel filter too because its been idling rough so hopefully a reset will fix both issues.
Thanks Steve.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
