Its a girl (again)
Thanks Andy :)
Following closely behind Matt (Bugalugs) Deb & Tayah!
Tania started contractions around 7.30am Monday morning, & finally @ 6.10pm that evening little Jasmine Emily was born :) :) :D Jasmine weighed in @ 6lbs8, was "also" 49cm long, & very close to 33cm head circumference!
Mum & bub are both doing really well :)
Bug's & I both with the first name Matt, both with R33 GTS25t's, & both have girls nearly identical in size!
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-59420
Originally posted by whatsisname
Thanks again guys :)
Shell,
         Don't do it girl! You'll end up watching all the crap on TV @ 3am in the morning :):D
Congrats Matt! :)
Jasmine was top of our list if we had a girl.
How bad is the TV dark o'clock??? :confused:
heh, now I offer to do the feeds only when RAGE is on :(
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-61957
Choosing a name you both like isn't easy hey!
Tania didn't want to know if it was a boy or girl till the actual day! Lucky it was a girl 'cause we were both set on the name Jasmine from the start :) A boy named Jasmine….hmmm.
The child restraints "may" get used in the Skyline, but it's unlikely. The RAV4 does all the domestic duties :)
Free to air TV in the wee small hours is pretty dodgy stuff :D Yeah RAGE is one exception, good thinking! Oh, & F1, MotoGP, Indy etc... Mind you those don't really qualify for "dark o'clock".
Cheers & thanks again :)
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-62291
Originally posted by red900ss
heh, now I offer to do the feeds only when RAGE is on :)
haha Dino you can't just do the weekend shift - that's not fair!!!
the weekday line up is very sad :D
although on Thursdays they have that crap they call football on at about 2.30am (AFL footy show).... oh oooops I'm in the SA section *they like it here*
/runs and hides.... :) :)
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-62296
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
