I have a set of Garrett GT2860-5s for sale.
Bought 6months ago from Kudos, never used, have sat in box in my house for whole time. Have taken off turbine housing as was planning to send away to have ceramic coated. Have all nuts and bolts and both actuators.
Selling due to never ending list of bills to pay.
$2000 non negotiable plus freight.
PICKUP PREFERED from Melb, south eastern suburbs
can be contacted on 0438383062 anytime
cheers,
Andrew
https://www.sau.com.au/forums/topic/358971-fs-garrett-gt2860-5s/
Will upload some tonight. Do have photos on my iphone though of turbos and cartridge id plates so if you'd like to pm your phone number i can send them through
pics as promised, sorry for the lateness.
Am open to offers but remember these are brand new, un-used and go for $2400+ from any SAU buisness trader. Am asking $2000k plus postage. Good bargain if your in the market for new turbos.
Cheers Guys,
Andrew
  • 1 year later...
  • 3 weeks later...
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
