hi guys. After bieng repeatedly ripped off over the last few years in regional queensland, i think its time to look into trying efi tuning myself. Now, i have an exceptional knowledge of all things auto, well, nearly all as im a TQ mech, but ive been away from the trade for quiet some time. I want to know if any of the brains here know of a tuning course or someone willing to have me sit in on thier time with them as a scholar. I find it hard to justify paying 2k for a tune then the "minimum fee of 750 dollars" to have the car seen to every time i change something. Exceptionally frustrating to say the least. so, if you know of something, please post away or if you would like to keep it discreet you are welcome to pm me.
Cheers, allan
https://www.sau.com.au/forums/topic/359141-efi-tuning-coursesprograms-in-qld/
Cheers, allan
Good auto knowledge coupled with some good resources on the net, you can be doing basic tuning easily I reckon.
There's thing that you can't really do on the street like playing with ignition timing - you need a dyno to measure power to find MBT timing.
Buy yourself an Innovate LC1 wideband kit, mine works flawlessly, people suggest other brands though.
Laptop + .tuning software + data logger you can pretty well tune your car.
not that hard. cruising: 14-15, 0psi: 12-13 boost: 11-12.
for cold start you'll need about 15-20% more fuel, then it's just a case of setting rev limiters, idle things, accel pump and thermo controls, all easy to pick up.
well, that's what I did anyway :)
thanks for the links and tips. I have called motec and they will call me back regarding a course in qld, depending on interest of course. I am waiting on a wb kit to show up and am trying to deal with the local shop to see if i can hire thier dyno but they do not seem all that keen
well, depending on the numbers, venue they can obtain ect ect. im still waiting on a call back, maybe mid next week by the sounds of it as they seem to be preetyy busy there at the moment with overseas customers chewing up thier time. Ill keep u all updated nonetheless
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
