LOl? And who told you it doesnt have a Knock sensor? IF you have one it must be broken or you havent picked that option :D.
Cause my Power FC has everything from Inj Duty to Knock to Air to Water temp. :D No gauges needed here mwahaha
+1 Power fc
Sid
Yeh I said knock control not knock sensors. If your engine is knocking then the power fc won't do anything to stop it, it will just flash a little light at you. Nistune will switch to a knock map automatically.
well I think I'm qualified to answer this. I've had power FC's in about 8 of my cars. they are great. easy to tune, reliable, cheap to buy (well except for RB25). hand controller is very handy (lol), they do lots of little things very well (nice stable idle, good injector control, good auxillary control, good base maps).
I recently had the power Fc in my silvia (SR20, trust turbo kit, nismo 550cc injectors, Z32 AFM etc) replaced with a nistuned ecu. to be honest it runs just as well on the nistune as it did on the power FC. however in the little silvia which has no aftermarket gauges I do miss the handcontroller to check things. that's about it.'
there is really not much to choose between them.
CarPC + Datascan ;)
I also have the NIStune software on my carpc but that's a little too full on for day-to-day monitoring and diagnostics.
Edited by bubba
thanks for all the replies guys
i currently have a power fc for my rb20 that i paid $1600 for about two years ago so i don't want to get rid of it if i can help it, i know there is a different model for the rb26 but will my power fc run a rb25 fine or is there a different model for that one aswell???
CarPC + Datascan ;)
bubba can you post up a pic or a link of the setup? sort of interested in seeing the display for datascan?
No pics handy but here is their website, pretty sure it's made by the same people that run plmsdevelopments and NIStune.. http://www.nissandatascan.com/
I've got the original Nissan Datascan I, not the new Dash version. The latest software even has support for a few widebands, allowing you to include the wideband readings in your datalogs.
Oops sorry didnt know thats what you meant :D.
And the your point is? its not really hard to look over for a split second its mounted right infront of me anyway. So mount gauges on your frame and get defected ^.^ Really whats the point of them unless your car is a track car? I think the hand controller is enough. No one in a street car in there right mind needs to know the Exhaust temperature.
Sid
Sid
Well Power FC is a defect anyway so not like that really matters.
I have oil temp, water temp, oil pressure and boost. All pretty vital, and when I'm warming the car up I don't give the car more than half throttle until oil temperature is at 80 degrees and oil pressure is sitting just above 60psi. I have an ARK MFD in my car as well as the guages, the screen would be a bit bigger than that on a PFC hand controller but I still find it impossible to read while driving. I mainly use it's peak recall and alert settings to check up on things.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
