Hey fellow wagoneers,
Noticed yesterday for the first time during some highway driving a bit of smoke creeping in from under the facia that surrounds the gearstick. It only seems to be happening at 80km/h + and smells of a slight burning. I slow down and it just seems to go away. Im hoping its something minor such as the oil in the gearbox just needs to be replaced as i just purchased the car not long ago hoping its not something major. The smoke is a grey/black in colour i guess?
Looking forward to your replys guys
https://www.sau.com.au/forums/topic/359341-wgnc34-gearbox-issue/
my mate has this same problem with his series 2, only happens in 5th and only at highway speeds.
I was thinking it was just his leaking rocker cover gasket leaking onto the turbo. but i've never really investigated a solution fully.
Hey there,
could well be that, interested to hear some more opinions since your spot on with how you explained it
cheers man
get under there and start looking for leaks.
smoke/smell is an indication that a fluid is burning - either due to friction, or because it is landing on something hot. the colour of the smoke can tell you what the fluid is, but at this stage probably the easiest thing is to get in the engine bay and look for wetness.
it might not even be gearbox related.
Dont know about manuals, but the auto box has a breather pipe and if oil is venting out it may hit the hot exhaust.Perhaps at a certain speed the fluid is blown onto the exhaust
Edited by 66yostagea
i'd say it'd be engine oil leaking onto the exhaust because;
a) the rocker cover always leaks oil from the rear corners, the bolts come loose
b) when doing highway speeds in 4th or 5th the engine is bascially idling, which ,means that the viscous fan will barely be turning(ie not blowing heaps of air past the box area)
c) get an auto, they are cooler anyway.
give that area of the engine a good degrease, retension the bolts(or replace the gasket) and retest :thumbsup:
  • 4 weeks later...
hey mate i had this problem when i got my stagea 3 years ago .it turned out to be the rubber seal around the gear stick was torn .u got to remove the plastic trim and then the large rubber cover held in by four bolts then u will sell the rubber seal . as u drive for a while oil simply spits out that seal and sits ontop of the gear box and starts to smoke . i just had to buy a complete new gear sick with the seal already installed so it was a remove and refit new one from nissan it was around $150 i think annoying problem costly fix.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
