So my 4door is going track only,so no need for most of the interior..
Think ill limit any single item to $50 as i just want it all gone....
So the interior is from a 94' r33 4door series 1
The things I'm not selling from the interior are the DASH,STEERING WHEEL,GEAR STICK SURROUND,FRONT DOOR CARDS and FRONT SEAT BELTS.
Everything else can go,from the floor to the roof lining..!!
Front seat are $50 each
Rear seat $50
Rear seat belts $50
Rear door cards $35 each
Roof lining $35
Anything else just ask and ill think of a price,and the more you buy ill make it cheaper..
I also have:
R33 COUPE rear bar,white with one scratch $50
Trust muffler with 5in tip,oval muffler measuring 400mm long and 280mm wide $50
R33 Stock Suspension with king spring low coils $50
R33 4door washer bottle with both pumps $15
R33 cross over intercooler pipe,and another bit to suit front mount $20
GFB atomic boost controller $30
Located 30min south of NEWCASTLE
Mainly after pick up,can meet up if your not to far away,and can post smaller items...
https://www.sau.com.au/forums/topic/359362-r33-4door-interior-4sale/
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
