Hi guys,
I will start by saying that my clutch is presumably a twin plate. The seller assured me it was and I took his word. It rattles like hell when depressed. I have not been near a confirmed twin plate equipped car to compare sounds to know if I have a twin or if the rattle is something else.
Anyway I am having a few probs and would like opinions on whether they are clutch or box related or even both.
1. When I first had the car -7 months ago occasionally when I was slowing up to a stop and dipped the clutch it didnt actually disengage. It would start lurching forward about to stall and I had to literally use force to yank it into neutral. It was as if I had not pressed the pedal. Interestingly it hasnt happened for a long while.
2. In the last two weeks I have had a hard time putting the box into first gear. It sometimes needs a bit of force to go in. I dont hear a clash of metal just a big click sorta sound. But it is intermittent. Sometimes it is ok.
3. The pedal has excessive freeplay. Say about 30 - 50mm.
4. This ones hard to explain a bit. When the pedal is all the way up and I press it down its say 30mm freeplay to the point where I can feel the resistance it will sometimes stick there and the clutch pedal will only have say 1-2mm of play but will pop up again soon as I touch it or lift it up with my foot.
I have not noticed any slippage but dont know a sure fire procedure to find out. My neighbour said to chock the front wheels against a gutter, put it in fifth and slowly let the clutch out. If it dont stall the clutch is on the way out. Does this sound right?
Lastly, with the excessive freeplay, can it be adjusted to reduce the play and could it be the cause of my probs.
I sincerely apoligise for the lenghty post but know if I go to a mechanic they will more than likely try to slug me for a new clutch no matter what. Would rather know what I am talking about before I go in there if in deed I need to at all.
Thanks guys
Jayson.
https://www.sau.com.au/forums/topic/35955-clutch-or-box-is-fcked/
Im not saying this is the best idea but if it was my car this is what I would do.
Take it to a decent workshop i trusted and get them to check it out properly, pull the thing out if necessary. It might need some work. That way you could identify the type of clutch and whether its worn or not.
At the moment it sounds like you may be causing undue wear and stress on your gearbox which i dare say is more expensive than the clutch.
how much do they go for.. can you use ones off others cars? i heard someone talking about using S13 cylinders on my R32.. will that work at all.
FATGTS-R - this sounds like what is going on in my car at the moment to. its really hard to get it into gear when in a stationary poisition and not that easy into other gears when moving. i think in my case its the master/slave cylinders not pushing the clutch in enough to engage the clutch properly, therefore not getting into gear. the rod that comes out of your master cylinder into the top of the pedal can be adjusted. don't know if this works i haven't done it yet. i want to get the cylinders checked out.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
