Hi all, just picked up my new r32 gtst on friday, very happy with the car but there is this annoying issue the car has with the cluster. The cluster is standard apart from changed dials ie there now white and blue, but the actual markings are all the same as original.
So the tacho in the cluster, its not acurate at all, i can be drving at say 3,000rpm and if i put it in nuetral it will take maybe 4-5 seconds for the tacho to drop to the actual engine speed. You can hear the engine revs drop instantly to idle but the tacho just does nothing for a bit.
Same thing when reving the engine, its like it lags and doesnt know wtf is going on.
The car currently is running a microtech lt10, could that have anything to do with it? Maybe its not getting a good signal from the ecu? All my other skylines had accurate and quick responding clusters, so whats up with this one?
The speedo is also out by alot, i'm not running massive wheels either, 17's all round. Its out by atleast 20kmh, my gps will say im doing 80 but the speedo says 100.
Any ideas?
https://www.sau.com.au/forums/topic/359669-cluster-issues-r32-gtst/
Have a mate with an R32 cluster you can swap over? Does it still run an RB20 + box? I think it would be the cluster itself, as the rb20 still uses a mechanical speedo. Given that you have problems with the tacho and the speedo, I think whoever played with the cluster shanked it.
Ok cool, were bouts u located? Yea still running a 20 and standard box.
Yea thats what im thinking to, I'm not sure why they even did it, looks horrible at night, the blue led's are to bright and shine through the cluster and blind you lol.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
