Hey guys,
small favour for a good mate of mine who just purchased an R34 GTR and is looking to upgrade the exhaust. He has no interest/time in the forums (so he claims) pfft :rant:
Anyways, i made him settle for the Amuse R1 Titan catback cos it looks and sounds insane or even the Trust TI or Kakimoto Full Mega as a slightly cheaper option and also metalcat highflow.
Im a little unsure for the front section, im assuming it should be changed to keep the flow all nice and even as opposed to stock, but can anyone offer suggestions on front pipes/dump pipes? Links are not necessary but wouldnt hurt.
I used some JJR gear when i had the R33 few years back, quality was great and fitment was ok but i remember there being slight hissing sounds due to small leaks etc.
Edited by TUFF_350
https://www.sau.com.au/forums/topic/359978-r34-gtr-exhaust/
forget titanium,
Get a full turbo back exhaust, there is f**k all to be gained in a catback on a stock front system.
Kakimoto full mega n1 whatever it is is two twin pipes that never meet and run parallel down the length of the car, probably not what you want (LOUD).
Just get a nice catback of whatever brand he likes and add the biggest highflow cat you can afford.
once you have this, find a frontpipe, there are alot of copies available now but honestly just grab a HKS one from Nengun or something for 600 or so bucks.
https://www.sau.com.au/forums/topic/359978-r34-gtr-exhaust/#findComment-5747854
Yea we saw that HKS unit but were unsure if you also needed dump pipes. So im assuming no is the answer to that one? Also maybe i typed the wrong Kakimoto unit as the one we saw is single pipe not the ultra loud double system lol.
https://www.sau.com.au/forums/topic/359978-r34-gtr-exhaust/#findComment-5747889
Hey mate, generally most of the front pipes will bolt up-to the standard turbocharger arrangement.
You will find if it doesn't it will list this.
should you be unsure just be sure to check with the person you a purchasing it from or do a forum search.
For what it's worth, I had a HKS front pipe behind my R33 N1's it it bolted up perfectly.
You might be thinking of the Kakimoto Regu I think it is called, very nice sounding exhaust.
How far you go with the exhaust will depend basically on what turbos the car has/ will have.
If your mate will want more power in the future (he will) don't get a restrictive system, you will end up changing it down the track anyway.
As has already been stated R34 GT-R dump pipes are very good and you won't need improved ones until you add another 150kw to the standard figure (just as an arbitrary base)
I would go,
HKS front Pipe + VENOM high flow cat (google search like $230 delivered and they are about as high flow as you can get with still having the mesh inside it) + HKS HI-POWER silent.
https://www.sau.com.au/forums/topic/359978-r34-gtr-exhaust/#findComment-5747996
I would go,
How much did it cost you to get the flanges welded onto the end of that venom cat
https://www.sau.com.au/forums/topic/359978-r34-gtr-exhaust/#findComment-5748205
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
