I have R33 GTR brakes on my GTS-T, but we never changed the master cylinder to a BM57.
Now it seems I have a little leak in my seals so I'll get the GTR master cylinder fitted.
We've also noticed the GTR booster is bigger then GTS-T.
Is it worth changing this too ?
Looking at the clutch master cylinder, it's very close already and may have to be moved.
Anyone know if the GTR booster will go in GTS-T without dramas.
cheers
https://www.sau.com.au/forums/topic/360189-r33-brembos/
Why get a GTR master unless you were unhappy with the travel/feel of the GTST one?
I thought travel/feel is more booster related anyway ?
And master cylinder more related to stopping quicker.
I may be wrong, don't know.
Can anyone please tell me what to expect with the larger diameter booster, or is it a waste of time and money.
cheers
https://www.sau.com.au/forums/topic/360189-r33-brembos/#findComment-5753222
BM 50 will shorten up the pedal a bit if you can't find a BM57. Larger diameter shortens the pedal but increases the effort required so if you fit a bigger booster as well it may be a help.
Yeah I've bought a brand new BM57.
You reckon pedal effort will increase without bigger booster ?
Edited by conan7772
https://www.sau.com.au/forums/topic/360189-r33-brembos/#findComment-5753250
Well it should in theory but maybe not enough to be a problem. I have been using the stock BM50 M/C with GTT brakes but have just got some 330mm 8 pot D2s (AP copies) for the front so I am looking for a BM57 m/c. If it deosn't come with a booster will see how my present one works. Let us know how you find it!
https://www.sau.com.au/forums/topic/360189-r33-brembos/#findComment-5753527
Kudos Motorsport in the Gold Coast have new ones in stock. $467 + $30 del. Master alone.
There's a wrecker in Greenacre, has an old one for $200 in fair condition.
I reckon parts will become very hard to get soon after what Japans been through.
You can order recon kits for the BM57 but right now it's a 12 week wait. The kits are $260.
Then you have to pay for a specialist on top to hone and fit.
https://www.sau.com.au/forums/topic/360189-r33-brembos/#findComment-5753616
Luckily I just picked up a genuine Nissan repair kit for $25 a couple of days ago! Second hand m/c go for $80 to $100 and usually come with the booster but the booster from my Stagea which was originally an auto may do the job. Everything's cheaper in the promised land although we don't earn as much as you Aussies!
https://www.sau.com.au/forums/topic/360189-r33-brembos/#findComment-5753779
  • 1 month later...
I have a r33 gtst with gtr brakes all round and I was not happy with the factory feel so I fitted a Nissan patrol master cyl, these are larger than the gtr one and do not have a bias valve in them. This way I could fit a in line bias valve and dial in what ever I wanted. I have been using it for three years or so now and I am very happy with it.
https://www.sau.com.au/forums/topic/360189-r33-brembos/#findComment-5856469
howd this end up all working. i have GTR brakes all round on my BM44 abs equipped r33 gtst s2 and not overly happy with the pedal feel after install
thanks
Pedal feel is nearly always a sign that you need still more bleeding (supposing that you have renewed the fluid preferably with something like Motul RBF600).
https://www.sau.com.au/forums/topic/360189-r33-brembos/#findComment-5856857
Josh, when i had the brembos on my 34 i also had a spongy peddle, i used a bm57 to. Only thing i didnt change was the air separator the comes off the booster and plumbs back into the engine. Try finding one of them as all GTR's have them.
https://www.sau.com.au/forums/topic/360189-r33-brembos/#findComment-5863817
Luke, what does this thing do? You said it's a separator, so it separates vacuum? air? from what?
And I don't think it would feel any less spongy with this thing on.
Boz22n, what diameter BMC did you end up using? What bias adjuster? Ever had any troubles with adjustment range being insufficient, i.e. too much/not enough front/rear bias?
https://www.sau.com.au/forums/topic/360189-r33-brembos/#findComment-5864506
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
