here is another updated list of parts left - i still have more to add :)
please note reduced pricing as hightlighted in red!
1. gearbox - $750 PRICE DROP $700
2. front door trims - $200
3. rear door trims - $170 PRICE DROP $150
4. dash cluster with 180km/h speedo (showing 73000km) - $150 PRICE DROP $130
5. doors (includes tinted glass & power window mechanisms) - $320 PRICE DROP $300
6. front windscreen (with antenna) - $150 PRICE DROP $130
7. rear tail lights - $160 PRICE DROP $130
8. factory afm - $50
9. blitz icolor dual solenoid dsbc boost controller (with user manual) - $600 PRICE DROP $570
10. attesa 4wd pump - $350 PRICE DROP $300
11. input shaft for transfer case/4wd - $50
12. work wheel nuts - $120 PRICE DROP $100
13. hicas pump - $120 PRICE DROP $100
14. ohlins suspension, very nice ride & not too hard/bumpy like most coilovers - $400 PRICE DROP $350
15. rear subframe 'pineapples' to lock in blown out bushes & stiffen rear end - $70 PRICE DROP $50
16. spare wheel - $50 PRICE DROP $40
17. dash vent (passenger side) - $50
18. left cv with knuckle assembly - $150 PRICE DROP $120
19. right cv with knuckle assembly - $150 PRICE DROP $120
20. drivers side window/mirror control - $80 PRICE DROP $70
21. sun visors - $30
22. complete boot trim - $160 PRICE DROP $120
23. instrument panel surround (does not have headlight switch & wiper button) - $40 PRICE DROP $30
24. power steering line - $40 PRICE DROP $30
25. caster (radius) rods (bushes are good) - $80 PRICE DROP $60
26. radiator overflow bottle - $30 PRICE DROP $20
27. passenger & drivers side door sill garnish - $80 PRICE DROP $60
28. door seal finish - $30 PRICE DROP $20
29. factory side skirts (black) - $180
30. front subframe - $60 PRICE DROP $50
31. bootlid rubber seal (no tears) - $30 PRICE DROP $20
32. power steering reservoir - $20 PRICE DROP $10
33. earls braided brake lines (front and rear) - $120 PRICE DROP $100
34. factory blow off valves complete with plumbing - $130 PRICE DROP $100
35. gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - $350 PRICE DROP $300
36. 'race brakes' race compound pads front & rear - $180
37. passenger side window switch - $40 PRICE DROP $30
38. genuine black gtr bootlid badge - $70
39. full set of front & rear gtr seat belts in good condition - $100 PRICE DROP $70
40. os giken triple plate clutch - $1700 PRICE DROP $1650
  • Replies 386
Plastic fuel cap I have.
Are u referring to the boot release cable which runs from the drivers seat?
sorry for late reply, yes i am referring to the cable which runs from the drivers seat.
cheers
stock gtr blow off valves i take them and the brake booster reservior that sit in the right hand corner next to the booster include the hoses .
pm send
pm send
pm sent mark
sorry iplen - reason the pm's were not coming thru is because my inbox was full, ive made more room though so pm's will no longer bounce
another update of the list of remaining parts with revised pricing :)
1. gearbox - PRICE DROP $650
2. front door trims - PRICE DROP $180
3. rear door trims - PRICE DROP $120
4. dash cluster with 180km/h speedo (showing 73000km) - PRICE DROP $110
5. doors (includes tinted glass & power window mechanisms) - PRICE DROP $270
6. front windscreen (with antenna) - PRICE DROP $100
7. rear tail lights - PRICE DROP $110
9. blitz icolor dual solenoid dsbc boost controller (with user manual) - PRICE DROP $550
10.attesa 4wd pump - PRICE DROP $250
11.hicas pump - PRICE DROP $80
12.spare wheel - PRICE DROP $30
13.dash vent (passenger side) - $50
14.left cv with knuckle assembly - PRICE DROP $100
15.right cv with knuckle assembly - PRICE DROP $100
16.drivers side window/mirror control - PRICE DROP $60
17.sun visors - PRICE DROP $20
18.complete boot trim - PRICE DROP $100
19.instrument panel surround (does not have headlight switch & wiper button) - $30
20.power steering line - PRICE DROP $20
21.caster (radius) rods (bushes are good) - PRICE DROP $50
22.radiator overflow bottle - PRICE DROP $15
23.passenger & drivers side door sill garnish - PRICE DROP $50
24.door seal finish - PRICE DROP $10
25.factory side skirts (black) - PRICE DROP $160
26.front subframe - PRICE DROP $40
27.bootlid rubber seal (no tears) - PRICE DROP $20
28.power steering reservoir - PRICE DROP $10
29.earls braided brake lines (front and rear) - PRICE DROP $80
30.gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - PRICE DROP $250
31.'race brakes' race compound pads front & rear - $180
32.passenger side window switch - PRICE DROP $20
33.genuine black gtr bootlid badge - PRICE DROP $50
34.front gtr seat belts - PRICE DROP $50
35.os giken triple plate clutch - PRICE DROP $1550
Please note that the above after market parts have done no more than 2000km & if there is any damage on any of the parts I would have most certainly mentioned it next to the item...in other words, all listed parts are in very good working order & generally unmarked.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
