here is another updated list of parts left - i still have more to add :)
please note reduced pricing as hightlighted in red!
1. gearbox - $750 PRICE DROP $700
2. front door trims - $200
3. rear door trims - $170 PRICE DROP $150
4. dash cluster with 180km/h speedo (showing 73000km) - $150 PRICE DROP $130
5. doors (includes tinted glass & power window mechanisms) - $320 PRICE DROP $300
6. front windscreen (with antenna) - $150 PRICE DROP $130
7. rear tail lights - $160 PRICE DROP $130
8. factory afm - $50
9. blitz icolor dual solenoid dsbc boost controller (with user manual) - $600 PRICE DROP $570
10. attesa 4wd pump - $350 PRICE DROP $300
11. input shaft for transfer case/4wd - $50
12. work wheel nuts - $120 PRICE DROP $100
13. hicas pump - $120 PRICE DROP $100
14. ohlins suspension, very nice ride & not too hard/bumpy like most coilovers - $400 PRICE DROP $350
15. rear subframe 'pineapples' to lock in blown out bushes & stiffen rear end - $70 PRICE DROP $50
16. spare wheel - $50 PRICE DROP $40
17. dash vent (passenger side) - $50
18. left cv with knuckle assembly - $150 PRICE DROP $120
19. right cv with knuckle assembly - $150 PRICE DROP $120
20. drivers side window/mirror control - $80 PRICE DROP $70
21. sun visors - $30
22. complete boot trim - $160 PRICE DROP $120
23. instrument panel surround (does not have headlight switch & wiper button) - $40 PRICE DROP $30
24. power steering line - $40 PRICE DROP $30
25. caster (radius) rods (bushes are good) - $80 PRICE DROP $60
26. radiator overflow bottle - $30 PRICE DROP $20
27. passenger & drivers side door sill garnish - $80 PRICE DROP $60
28. door seal finish - $30 PRICE DROP $20
29. factory side skirts (black) - $180
30. front subframe - $60 PRICE DROP $50
31. bootlid rubber seal (no tears) - $30 PRICE DROP $20
32. power steering reservoir - $20 PRICE DROP $10
33. earls braided brake lines (front and rear) - $120 PRICE DROP $100
34. factory blow off valves complete with plumbing - $130 PRICE DROP $100
35. gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - $350 PRICE DROP $300
36. 'race brakes' race compound pads front & rear - $180
37. passenger side window switch - $40 PRICE DROP $30
38. genuine black gtr bootlid badge - $70
39. full set of front & rear gtr seat belts in good condition - $100 PRICE DROP $70
40. os giken triple plate clutch - $1700 PRICE DROP $1650
  • Replies 386
Plastic fuel cap I have.
Are u referring to the boot release cable which runs from the drivers seat?
sorry for late reply, yes i am referring to the cable which runs from the drivers seat.
cheers
stock gtr blow off valves i take them and the brake booster reservior that sit in the right hand corner next to the booster include the hoses .
pm send
pm send
pm sent mark
sorry iplen - reason the pm's were not coming thru is because my inbox was full, ive made more room though so pm's will no longer bounce
another update of the list of remaining parts with revised pricing :)
1. gearbox - PRICE DROP $650
2. front door trims - PRICE DROP $180
3. rear door trims - PRICE DROP $120
4. dash cluster with 180km/h speedo (showing 73000km) - PRICE DROP $110
5. doors (includes tinted glass & power window mechanisms) - PRICE DROP $270
6. front windscreen (with antenna) - PRICE DROP $100
7. rear tail lights - PRICE DROP $110
9. blitz icolor dual solenoid dsbc boost controller (with user manual) - PRICE DROP $550
10.attesa 4wd pump - PRICE DROP $250
11.hicas pump - PRICE DROP $80
12.spare wheel - PRICE DROP $30
13.dash vent (passenger side) - $50
14.left cv with knuckle assembly - PRICE DROP $100
15.right cv with knuckle assembly - PRICE DROP $100
16.drivers side window/mirror control - PRICE DROP $60
17.sun visors - PRICE DROP $20
18.complete boot trim - PRICE DROP $100
19.instrument panel surround (does not have headlight switch & wiper button) - $30
20.power steering line - PRICE DROP $20
21.caster (radius) rods (bushes are good) - PRICE DROP $50
22.radiator overflow bottle - PRICE DROP $15
23.passenger & drivers side door sill garnish - PRICE DROP $50
24.door seal finish - PRICE DROP $10
25.factory side skirts (black) - PRICE DROP $160
26.front subframe - PRICE DROP $40
27.bootlid rubber seal (no tears) - PRICE DROP $20
28.power steering reservoir - PRICE DROP $10
29.earls braided brake lines (front and rear) - PRICE DROP $80
30.gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - PRICE DROP $250
31.'race brakes' race compound pads front & rear - $180
32.passenger side window switch - PRICE DROP $20
33.genuine black gtr bootlid badge - PRICE DROP $50
34.front gtr seat belts - PRICE DROP $50
35.os giken triple plate clutch - PRICE DROP $1550
Please note that the above after market parts have done no more than 2000km & if there is any damage on any of the parts I would have most certainly mentioned it next to the item...in other words, all listed parts are in very good working order & generally unmarked.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
