For Sale is Ohlins Coilovers for a R33/R34 GTR.
Excellent Condition with no leaks, hard to find item, especially in this condition.
Features of the Coilovers are;
height adjustable
Dual Flow Valve
Rebuild-able
PCV Screw Height Adjustable with Upper Pillow
10k Front Springs, 8k Rear
Selling for $850 plus postage, Pick Up available in South Australia (Metro).
Contact Shane - 0411 475 779
https://www.sau.com.au/forums/topic/360306-ohlins-coilovers/
