hey guys my gtr 32 is chugging when goin about 80 kms it only does it in 4wd mode
is it because car too low ??
what could it be its deff in drive chain not engine weird
please help if ya can
diff size tyres from front to back .. but it has always done it a bit and got worse now only in 4wd really annoying
but i had squeak in suspension checked and they said it sitting on bump stops at front
fluids are fine i repalced some copper washes at attessa pump because was leaking .
whats best thing to do ?
A problem right there (not *the* problem though I don't think), ATTESSA expects same size tyres all around (best to stick to same brand).. even with the same brand tread difference between front and back can trip ATTESSA up. ATTESSA wasn't meant to be run fulltime, even if it's a tiny bit from the tyre difference the damage to the transfer case (clutch packs in particular) might already be done.
Even when I had 235/45/17's all around, with the new ones on the front and worn ones on the back it was enough of a difference to produce this effect.
What rims and tyres are you running currently?
Shouldn't ever do it in 2WD mode. As per the several thousand other threads that discuss this problem, the ATTESSA thinks the rear wheels are slipping, because they are smaller rolling diameter than the fronts, and therefore rotate faster.
I am still at a loss as to how many times we have to tell AWD owners to match the front and rear wheel / tyre sizes.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
