Nice work Adrian, I had people looking at me all funny when I was cheering from behind the pit wall when you did that 12.5sec @ 116mph...
Now... back to finding where I can gain 0.7sec in my car without replacing the driver
:bananaman
  • Replies 112
116mph as buster said is around 260rwkw`ish.
congrats on the time 2rismo with slicks you should be able to get very close to a 11. good luck
nicknick i went 12.601 @ 120mph with an rb25 and t88 - running only 345rwhp. i dont mean to be rude but your time with c16 isnt impressive - sure its quick but not for the mods its got. the mph suggest you have around 300kw's. good luck with it though
Yeah I was thinking Adrian would've had around 260-270rwkw. I've had slightly higher mph and similiar rwkw.
Nitrous is bloody impressive stuff! A 50hp shot gives a HUGE improvement.
the mph means nothing, i have dyno sheets on over 400 rwkw if you want to have a look, with an 8 grand launch i had so much wheel spin i couldnt keep traction, and with the clutch slipping in third gear im impressed that it held at all after that launch. but anyways the new clutch is going in this week so next week hopefully will run a beter time, i was also unimpressed with my time, but then again i needed a bad time so i can beat it this week.
i ran a 11.8 @ 124 mph and 11.6 @ 120mph. prooving mph means nothing when it comes to the quatre. anyways i wont know what happends till next week. will run it on pulp next week just so i know what its cappable of doing on the road not just the creek.
Dyno sheets mean nothing, quarter mile times and mph dont lie.
...however 1/4 Mile has a lot more to do with the driver than a Dyno does. My 60ft and TS time/speed show using data from 80 1/4 times on my website) that my car is 'capable' of a 13.8sec although im still hovering around 14.1's so how is that an accurate record of the power my car is making when my 1/4 time is slower than what it should be? (i'm lacking mid-top end).
wreckedhead,
saying that mph means nothing in quarter mile drag racing is about the least correct thing i have ever heard said on the subject.
thousands of drag racers for about 100 years would beg to differ.
dyno sheets mean ABSOLUTELY NOTHING!
To answer the previous question, i will speculate that the car is making about 250-260kW @ the wheels. Will check this in the coming weeks.
Adrian
A real world drag strip MPH figure is a faaar bigger indicator of performance potential than any dyno number. So yeah, couldn't agree with you more Adrian.
I ran 13.0 @ a best of 115.8mph (2.2-2.3 60ft from memory) with ~260rwkw.
Unless you cant keep your foot buried to the floor and change gears swiftly, then mph will be a good indication of potential, of course when you get the quality run your mph will increase, but not significantly, Oftens its found that mph drops slightly when you run that perfect run due to lack of wheel spin
RB20LagWagon - Couldn't agree more.
My highest ever mph is 116.10. Combined with a 2.294 60', this gave me an ET of 12.970
With a lower mph of 115.45 and a much better 60' time of 2.001, I ran a 12.585.
Adrian
Guest INASNT
2rismo
So if u r making 250kw@wheels have u upgraded your fuel system?
My limited understanding of NOS is they it speeds up the combustion process by helping burn more air and fuel than normal hence creating more power.
So using NOS still means u need to upgrade fuel system and clutch atleast.
NOS also puts the same stresses on the engine as a big wack of boost from a bigger than stock turbo?
2rismo
Fuel pump is a Bosch unit but not running any more pressure than std (std reg still in place etc). Extra fuel for the extra oxygen to burn is injected through the same nozzle in the inlet. Nothing extra req'd from the injectors.
Adding Nitrous Oxide (N20) increases dramatically the amount of oxygen in the combustion chamber that is available to burn extra fuel. Remember, you dont make more power with JUST more oxygen.
What?>?!?!?! No. Clutch? Where'd that come from?
Almost, yes. Using N2O also dramatically increases combustion chamber temps, prob by more that upping the boost on a turbo (generally) so technically the motor is more prone to detonation.
Adrian
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
