Hey guys,
Looking to do my first Tassie trip in June. I'm looking at driving down and spending around 2 weeks.
Hoping to do a bit of travelling and spending a bit of time everywhere. 2 things I would love to see is wine glass bay & cradle mountian (obviously)..
Any places that people could sugest or B&B's that are a must visit?
Maybe could organise a night for a piss up :)
Cheers,
Corinne
https://www.sau.com.au/forums/topic/360398-tassie-holiday/
Yea it's a fully sik low taxi haha.. I will keep that in mind thanks for the tip :)
you will only have troubles if they try and put you down in the lower decks, but if you ask nicely they will let you stay up top
drive from launceston to scottsdale, thats a great road, and lake highway is supposed to be good too
i'd go from launceston down to hobart via the east coast, swansea is nice, its all pretty nice down the east coast
https://www.sau.com.au/forums/topic/360398-tassie-holiday/#findComment-5757061
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
