Any thing is possible if u have money to waste, If your doing it yourself and know what your doin id say a couple months depending opn your skill level & time allocated etc paying a garage or something if you could even find anyone willing to do it id say ud be lookin around 8-10k, but at least theyd do a good job. just buy another car if you had that sort of coin, I think Wangan Midnight does these sort of conversions in his shed, shoot him a pm he might be able to help you
Edited by rickr333
Wait. You're swapping an RB20det OUT of an N/A car? or swapping the DET with a DE engine? Either way, it's gernerally over capitalising.
If it's a non-turbo car, service it and sell it on to a P-plater. They pay top dollar for the privilege.
Use the money to buy a turbocharged car. Win win.
Edited by Truffles
Out-freakin-standing hahahahaha.
hooon, what was the car originally, gts or gtst. swapping an engine over is a lot of effort, your $500 quote is probably for just swapping an engine with another of the same engine with things going well.
The car would have required a new ecu, wiring loom, and engine, and the addition of an intercooler, plenty of piping, turbo etc etc to be changed from gts to gtst.
The NA section has heaps of info there if you search for it, sooooo many threads detailing engine swaps and costs etc.
Also why do you want to go NA anyways? If it were me I'd be putting an rb25det in there with a highflow turbo.
The car was originally a gts-t, I only want to swap the engine for a n/a beacause of the restrictions, no insurance etc, and the engines not in very good condition.
What restrictions? Are you a p plater?
Insurance? It is unlikely to be any cheaper for a highly modified car, which is essentially what an engine transplant is. Think about it, it's not a gtst, it's a gtst+engine swap, which is a lot harder to replace than just a gtst, which there are many of these days.
I'm guessing he would be a p-plater.
Yes it would be cheaper, probably. It doesn't matter about the "replacement" car. The insurance company will just give a value and payout according to that. They don't care what you replace it with once they give you the money.
I'd be double checking to see you can rego and insure a turbo car that's had the N/A engine swap, as a P-plater. Should be able to, but it's worth setting up before you spend all the money.
As I originally said; unless you can swap the engine yourself, it's not a financially smart option to essentially make the car worse than it already is. Buy a factory N/A or wait until you're on your open license and buy a factory turbocharged car.
Edited by Truffles
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
