Hey hows it going, i got a R33 GTS-T Series 2, i have a stock diff in this car and i would like to know if my revs are showing correctly on my spedo as when im doing 100ks an hour in my skyline it shows that im doing just under 3k in 5th gear is this correct as my SAFC doesnt show that it shows im doing roughly 2550-2600.
I aint sure who i should trust.
Yours Truly,
Nick
https://www.sau.com.au/forums/topic/360608-quick-question/
There are a heap of online calculators online which can tell you how much rpm you are doing at x speed. I'll see if I can calculate the rpm for 100km in 5th
According to this calculator in an R33 GTST with the standard 4.1 rear diff ratio, you would be doing just above 2500rpm at 100km/h. Your SAFC and dash read from the same signal, the digital is always better as it doesn't just go out of whack like the mechanical gauge would.
You shouldn't notice this just in 5th. All your gears and speeds are gonna be out. Get your cluster checked or replaced. Ive got a spare R33 GTST cluster with 118xxxkm on it. Works a treat and if you're in Sydney its yours for cheap.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/360608-quick-question/#findComment-5758478
Is there anyway to refurbish a tachometer as i dont want to really change the k's its done.
yea it can be fixed, its just a matter of finding someone capable of doing it as its a fairly tricky little precision instrument. alternatively if you obtain another tacho you can always get the mileage changed on it. this would be done by the same person who would repair them. when your asking around about it, make it clear that your not trying to wind back an odometer illegitimately. you've just bought a replacement for your car and want it to reflect your car's true mileage.
i've been through the same thing before, i found a guy that ran a small business fixing precision electronics like these and he got really suspicious when i asked him if he could change the odometer on the new tacho i'd bought, took a little convincing that it was legit lol.
https://www.sau.com.au/forums/topic/360608-quick-question/#findComment-5760716
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
