my friend just doing some teaching in the northern territory just got booked for doing 38km over the limit as he went from no speed limit to an 80 zone - prolly to fast to see the sign and the speed wasnt marked on the ground
anyways he got a fine of $160 and lost no points
what would be the norm if he got done in NSW?
https://www.sau.com.au/forums/topic/36068-booked/
He would have a NSW licence. From what I've heard (so don't quote me on this), if you get booked in another state, you don't lose points, but you still have to pay the fine. A friend of mine on his moto was booked in Victoria and he was expecting to lose points, but it never happened.
https://www.sau.com.au/forums/topic/36068-booked/#findComment-721144
Good to see people know their road laws!!
Over 35 is instant loss of licence in Vic.
- 25 or over is auto loss of license in Victoria
- used to be like this 5 years ago..... you lose points now in all states (unless the ticket doesnt have points) afaik.
https://www.sau.com.au/forums/topic/36068-booked/#findComment-721235
Guest INASNT
I lived in the Territory for 2 years and I find it very hard to believe there is a spot that goes from unlimited to 80 km/h without a 100 km/h in between.
I got booked doing 66 in a 40 zone up there.  Never left 1st gear.  ****en idiot! (me)
That happened to me while driving my lamborghini diablo sv once to, got doe for 80 in a 60 zone, and told the cop i was still in first gear, so how could i be speeding. :D
https://www.sau.com.au/forums/topic/36068-booked/#findComment-721309
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
