I've done the web search, read the reviews ect ect...
What I want is your opinions/experiences
I've got three I'm looking at:
BCU
HDi Will need to get a gauge for this one
AEM
This will be my first mod on the stag (bar a stereo swap) and dont have alot of coin to spend so want the best "bang for buck" and reliability
If you got any alternative suggestions let me know
cheers
https://www.sau.com.au/forums/topic/360704-anyone-used-these-boost-controllers/
The turbotech T boost controllers off ebay for $30 are the best bang for buck. Holds boost perfectly. The ball and spring is a simple but perfect design.
dude... theres many greddy profec b spec 2 on sau and ebay atm...
if u can jag one for under 300 ur on a winner!
by far the best value for money EBC.... small easy to use and u can hook up a hi/low switch to ur dash for under $5 and stash it away from police eye!!!
only owned a turbotech - which never failed me.
and a gizzmo MSBCII - bit fiddly to setup if you're not doing it on a dyno (but so are all EBC's) but i like it because it reads in PSI.
i have a Gizzmo MSIBC, excellent little unit and they come at a reasonable price, i got mine for $300 new, at the same time a Profec B SpecII was $900 new!!! i previously owned a Prefec B so i thought i'd try the Gizzmo, it does a very good job at holding my GT35 on 23psi. it took me a couple of days (trips to and from work) to find a good balance between the duty and gain so it would ramp quickly and would spike, but i haven't had to touch it since then.
Edited by QWK32
yer exactly. took a few runs on the backroads at night to get the gain set up properly. also got 6 settings, so you can put it down to stock boost if you want to save fuel or lend your car to someone.
other thing i like about it that its pretty non-descript. i have mine mounted in the center console and it's virtually undetectable - just looks like a black screen with the car switched off - could come in handy for roadside inspections.
you know what? i rekon having 'settings' on an EBC is useless. i used to think 'yeah ill one for wet days, one for when im driving fast and another if i take it to the track blah blah'
it never left the high boost setting. ever. none of them have lol
i regulate boost via my right foot
yeah i agree, i've never use multiple boost settings on my cars, always just set it to what i want and leave it. though i can see the benefit on say a manual car for drag purposes. the Gizzmo lets you go through presents from a remote button. so say you want to launch on 14psi but then once your off the line click the button and run 20psi.
I had a turbotech that was a bit of a lottery over 17-18psi. Perhaps they are better now at higher boost levels. At the time small increases on the boost controller led to large changes in boost level. Up to that point they are fantastic bang for buck boost controller.
I have Profec B's on both cars now and they are hard to beat for the price if you want to go electronic.
So I guess the verdict is in:
go buy a profec 2
But seriously NOONE has used any of those controllers here?
I can understand the first one looks cheap and nasty but the HDi and AEM look alright (and have pretty good reviews)
If I'm going greddy I'll have to get a second hand one, could there be any issue with the soleiniod being old and prone to failure? Anything else to watch out?
im currently using Ark advanced boost controller - finding it very good - simple enough to use too
might go to a HKS one soon but definatly happy with the ARK one which is also made in japan
i'd say a second hand brand name controller would be as risky as buying a no name controller......and when it comes down to it, boost regulation is not something you want to be running the risk of.
and to the guy running a turbotech at 18psi - probably more to do with wastegate spike than anything. its a lot to be running on an internally gated turbo and to expect a manual controller to be able to handle.
Quick question, whats so good about the profec? is it the proven reliability or is it something else that im missing? Starting to think maybe the aem is for me...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
