  • Replies 42
I'm using a Logitech G35 and find it awesome for gaming.
and +1 on never buying a Razer again... sent back one mouse under warranty and the 2nd mouse becomes problematic(same problem as the first) shortly after the warranty period expires... it was a Razer Lachesis. Before that I used a Logitech mouse and never had a problem. Now I'm using a Microsoft Explorer 3.0
lol the Lachesis was like a LS1. They had SO many problems with it that it ended up being a joke really.
yeah G35 is sweet...but a little more than i wanna spend.
the fatality is 50-60 bucks from what ive found where is it 40?
http://www.logitechshop.com.au/logitech-g35-s-sound-headset.html
keep an eye on that site.... fkn amazing specials; they had them for $95 inc delivery last week
z5500s for 290 inc delivery :P
don't always look @ price i have had my sennheiser's (HD212pro) for over 5 years now probably pushing 7, I know a lot of these cheaper brands break at the 7-8month mark so $50 for 8months or $112 for 7 years having replaced the cable @ $19.50 as well total $131.50 that's $18.78/year for my headphones and there is no sign of fatigue
I thrash my HD550's, so they are broken on one side (i just throw em around a bit). So they've survived 4yrs of solid abuse, almost daily.
Also IMo get headsets without the "mic" attachment and just buy a Zalma clip-on mic for $10
Get much better value that way
Wow
http://www.pccasegear.com/index.php?main_page=product_info&cPath=116_1219&products_id=17249
They are half price of what they were 3-4yrs ago. Would be a nice buy if you have a sound card, they are discontinued according to the USA website so maybe a clearance price.
Wow
http://www.pccasegea...oducts_id=17249
these look really comfy :) still double what i payed for my gamecons. I'll see how they last, will def look into these or similar if they dont
+good price on the logitechs
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
