just looking in and around the engine to see what will be affected if I go down the 26/30 road, if the head raises 28mm ( I've been told ) most stuff looks fine, I think my dump will be alright but the hypertune intake plenum will foul on the clutch master cylinder, I'm sure I'm not the first to come across this, so is there an adaptor or something for the clutch cylinder to move it 20mm ??? what have others done ??
  • Like 1
ok I've found an answer to my original question but now have a couple more : so people that have had this problem ( albeit in s13's and R32"s )have used R33 GTS clutch master cylinders, my car is an R33 GTR so is the GTS one shorter and will it be ok for an OSgiken triple plate ??
Do 33GTR's still have the clutch booster? not sure if the non-booster master cylinder will work with the booster...
Its on the fire wall right at the back of the intake beside the brake master, 1995 GTR, I assume its the clutch master, could be wrong, but what else could it be, seems to be the same problem others have had, ill see if I can upload a pic
<br />I got an aftermarket Terrano clutch m/c (no room for booster)  Terrano R50 30610-4W000<br />
<br /><br /><br />
what clutch did you run with that M/C, affect it at all ? mines OSGiken triple so pretty heavy, will the Terrano handle that....
<br />I helped build this motor(rb28), it all fits. Very close but went in. We covered the Plenum in tape prior to install. <br /><br />Matt<br />
<br /><br /><br />
what you helped build Allan's (SLY33) 28, which is now mine, has some detonation on #6 so engine has to come, so looking at the 26/30 option and sell the 28 bottom end- needing new pistons...
anyway how did you go getting yours in, or if you have a different plenum, is it not a problem?
<br /><br /><br />
Yep, Allan the Dentist. It has custom CP's in it from memory, James had them made up after the HKS pistons had issues. I remember how this engine revved.. I would be sticking with the 28 and just changing the turbo setup to be honest.
Matt
<br /><br /><br />
Some kind of aftermarket heavy duty single plate cutch came with the R33 GTR box. I think the piston is the same size (you could check with yours) so thats all that matters really. My clutch was already pretty heavy as no booster.
The point I was trying to make is that with 32GTR's, they run a vacuum assisted clutch (CLUTCH BOOSTER). This means that the master cylinder setup for GTR is different to GTSt and GTS4. If this is the case with 33GTR, then you won't be able to run a GTSt master cylinder.
<br />The point I was trying to make is that with 32GTR's, they run a vacuum assisted clutch (CLUTCH BOOSTER). This means that the master cylinder setup for GTR is different to GTSt and GTS4. If this is the case with 33GTR, then you won't be able to run a GTSt master cylinder.<br />
<br /><br /><br />\
ok thanks
I have an R33GTR gearbox and clutch in my Stagea - did without booster no problem (aprt from heavy pedal) and now with FF plenum have replaced clutch m/c with shorter (Terrano but other skyline ones will do also).
  • 5 years later...
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
