hhey guys before i put my rb25det in the vl i had a standard rb30 manual (mx7) i had a 5 puk button clutch that i used for like 3000kms. seeing though the flywheel is the same size on both r33 box will this clutch work on the r33 box?
https://www.sau.com.au/forums/topic/361081-mx7-clutch-in-r33-box/
Don't think so, the clutch is a little bigger on the vl. I almost bought a vl clutch but was told our cars are 240mm and the mx7 is 250mm or something. Then again the whole flywheel on an r33 is a flat surface so as long it's machined and the clutch cover fits the rb25det bellhousing and the starter motor teeth fit with no obstruction from the clutch cover I guess it could work...
Edited by SargeRX8
