yeah we could probably work something out to have a look maybe
if you want the plates make me an offer i cant refuse, see how you go.....
That would be awesome to have a look. Are you planning on bringing it out for the Toowoomba cruise?
came and looked at your car thurrrrsday?? afternoon
its a minter.... very nice, i wish mine was white
Thanks mate. I am really happy with it. I would love to get some photo's of mine car and your's if possible?
Any change of mind about bringing your car out of hibernation for the T'bar cruise?
Would be nice to have more then 1 Toowoomba skyline turn up, cause I have not been having much luck with other owners
i would but mine is not registered it just sits in the shed.... and for what it would cost me to register it for just that day its not worth it hey
if you wanna come look at mine ill consider, it and you can get your photos here if you like
instant rego can be arranged you know :P
i've recently moved up to Oakey / Toowoomba Gunmetal Grey R32 GTR ;)
Awesome. You doing anything this Sunday. big bunch of guys from Brisbane area are cruising upto Toowoomba. Would be good to see you there thumbsup.gif
I am keen to get amongst it but stupid friends have to hold stupid elaborate birthday parties that are on the same stupid weekend >_<
That sucks. Guess you will just have to make the trip down for happy laps at lakeside next weekend
What time sunday? And where? .. i'll see what i'm up too! Normally home in Brisbane though over the weekend :)
Around 10-10:30 up at picnic point then cruising down to Withcott for a feed
We could have a catch up tonight sometime if you guys are keen? suss out some details and what not?
lets bring thursday night laps back! but seriously...no
Yeah big no for Thursday Night Laps. Don't really want to have to deal with the 17y.o in there VN commy trying to race, I get enough of that on my way to and from work rolleyes.gif also don't want to have to deal with the police.
What about tomorrow say 6 at the Kearney Springs softball/touch carpark? Or we could do evening during next week?
i might head to picnic point too just look for my white ute.... ill come say hi if i can but i wont cruise i got a skyline to put together instead
where at picnic point chris??
another one ?
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
