Need it done tomorrow some way if any one could help would be much appreciated roady gets done Wednesday ha
It shouldn't be a problem for road worthy. I can have a look for you but won't be able to do so until the weekend.
Yeah but after the Time ive spent making it look gd it's not going on the rd with one side of the boot sticking out lol
Well what you could do is take the boot lid off, get a big hammer with a bit of weight to it a block of wood and on the end of the hinge hold the block of wood and hit it with the hammer. Do some measurements first as to how far the hinge has to go back so you don't have to keep taking the boot on and off to get it sitting right
That's it, just bend it back to where it came from man - that's the good thing about most metal parts ;)
skirts. what's goin on?
Just finished work and about to head to touch footy training. What's crackin with you? How is the knee? And more importantly where are these illusive pictures of my car from the charity cruise!
I do have some news about myself but will reveal it when the time is right
The knee is doing pretty well. I',m almost walking normally again.
You're pregnant?
Not you too...
Damit I told you to keep our love baby a secert!
But I thought it was ours?
But....but....you said you weren't seeing anyone else :angry:
Tom I thought you only had love for me??
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
    • You have to continuously fill it to avoid dry running. Personally the transmissions I've serviced have never been bad enough to justify doing this because it is definitely a pretty complicated and somewhat risky procedure compared to simply draining the pan, measuring what came out, then refilling with the exact same amount.
