  • Replies 376
Posted Images
Yeah its shit now, I was apart of the beta testers
Grinding tanks takes for ever they didn't fix an invisibility bug whereby a stationary tank can shoot you and your about 20m away and you still can't see him
I still play it as it is a bit of fun, and load up fraps just in case you need to take a Ss of some tk'er
https://www.sau.com.au/forums/topic/361318-world-of-tanks/#findComment-5767079
It's not a bug as such but I feel the cammo and spotting system could use a fair bit of work. There does also seem to be an issue with some people having tanks disappear when they shouldn't. I have not had that.
I love the guys sitting in heavy tanks or tanks 2-3 tiers above mine and they say 'go scout' why don't you go scout, I'll just be finding that there is a guy, somewhere, that can 1-shot me. Somehow I manage to never be the top tier tank.
Edited by DivHunter
https://www.sau.com.au/forums/topic/361318-world-of-tanks/#findComment-5767329
Ah and how long have you been playing, 1 weekend trust me its a bug
People having tanks disappear is due to radio range, if your radio only goes say 300m and your teamate goes further then they will disappear
I am aware of radio range and how it works, there are a small amount of people that both know how the spotting system works and have experienced tanks out in the open inside a very short range disappearing without cover. Most reports of invisible tanks are just due to not understanding how the system works.
https://www.sau.com.au/forums/topic/361318-world-of-tanks/#findComment-5767379
well give it some time dude i don't mean to sound harsh to you
me and my old man have been playing for sometime now maybe 10 months they didn't used to be invisible but once patch borked the spotting system and TD's seem to be the most effected
Group: Beta Testers
Active Posts: 38 (0.18 per day)
https://www.sau.com.au/forums/topic/361318-world-of-tanks/#findComment-5767764
  • 3 weeks later...
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
