  • Replies 376
Posted Images
Moving to SEA was a terrible idea.
It's like being in one of those NA games where most of your team mates are in one of those vietnamese clans and you just know they will be terrible at everything. Except it's all the time.
I just created a SEA server account so I could give it a try, I know what you mean and there are barely any tank companies.
The ping is good but really doesn't make that much of a difference to me. I think I'll keep my NA account where it is for now, I only have a few tier 5 tanks on it anyway.
I have many tanks including tier 10s etc.
Not happy, Jan.
This is the best summary I see:
In MMO terms, the E-75 is a vanilla warrior with shield, the ST-1 uses two handed weapons and full armor, the M103 is that asshole who uses the warrior class for the defensive bonuses and then uses crossbows, the IS-8 is the rogue that suddenly thought "warrior sounds cool, I might try that", and the VK4502B is the starting character with a tower shield. The AMX50-120 is actually a mage and simply wandered into the wrong raid group.
  • 4 weeks later...
http://www.mmorpg.com/giveaways.cfm/offer/376/World-of-Warplanes-Beta-Key-Giveaway.html
World of Warplanes close beta keys, if anyone is interested. Currently around 2200 keys remaining, you'll need to sign up to mmorpg.com to get it.
WOWP is crap
Don't bother - I have been playing since closed alpha and while it has improved alot it doesn't help playing with a 300+ ping
but WoWS is coming soon so hopefully that will be good
Edited by Damit
Am I the only person left who still plays WoT reguarly?
i do a few matches daily or every second day but depending on what other clan members are playing at the time I may not play at all for days
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
