Ahh lol I wouldn't drive too far for them. I don't know about deliveries but I picked up a bottle of 4 litre VMX castrol for $35, the tube of G70 for $10, nulon concentrated coolant for $30(5L). Repco/super cheap have these for $42, $15, $38 respectively. Got my spark plugs for $3 each. I'm not saying the savings are too huge but they are definitely cheaper than other general auto stores.
What are you after? I live like 2 mins from the shop I can check it out when I go in.
9632 3888
Edited by SargeRX8
https://www.sau.com.au/forums/topic/361319-guilford-spares/#findComment-5767463
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
