Tuesday 26 April at 930? there is also a 640 session but 930 works better if we are going to have dinner before hand, I have to work the next day but I think it will be worth being tired over
All those attending add their name to the below list:
Attendees:
nerm (+1 Maybe)
https://www.sau.com.au/forums/topic/361343-fast-5/page/2/#findComment-5768795
  • Replies 58
I thought Lemon Grass (as mentioned in your first post Nerm) was in Tuggers
Either way I'm not too fussed on where food is consumed. What's Trilogy though?
Im pretty sure there is a Lemon Grass in Woden.. also in Civic too i believe.
Trilogy replaced Babars and the food is essentially the same
https://www.sau.com.au/forums/topic/361343-fast-5/page/2/#findComment-5772683
    • Welcome back! There is a v series forum, a little quiet at times but every new active member helps
    • But, per MBS206's question, what happens when it doesn't start. When you turn the key to IGN, do the dash lights come on (then go off after a couple of seconds) - likely alarm or other electrical issue When you turn the key to STRT do you head a clear click (the starter solenoid trying) without the engine turning (likely starter motor)
