As mentioned last night at the meeting there is a Sandown track day being held by FFCC (Ford Four Car Club) in-between now and the next WRX event in July.
Sandown is great as it is close to Melbourne and generally within 30mins of everyone. Yes the walls are close to the track, just keep that in mind when
you press your right foot down.
Date
Sunday 8th May 2011
Price
$170
Requirements
CAMS L2S
CAMS club membership with current sticker (SAU VIC Membership)
Fire Extinguisher
Two bonnet latching mechs (the standard double latch is ok, but for older cars with the single latch no good you need a second with a tie down strap)
Blue battery triangle 150mm x 150mm x 150mm (get yourself some blue contact from the news agency and cut one up!)
Entry Form
http://www.ffcc.asn....0May%202011.pdf
Fill the entry in and post it off or email it to [email protected]
I printed it, filled the form out then took a picture with iphone and emailed it to them.
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/
  • Replies 93
Posted Images
lol what? Why didn't you just scan it to PDF and email it? i guess no access to a scanning device.... actually the photo thing isn't a bad idea! :D
Anyway I'll put my entry in after the Easter break, there's a few little things to sort out with the car before I enter. Decided not to do the Midland sprints at Winton the week before, this will give me more time to play around with the car :thumbsup:
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/#findComment-5773611
Yep it's a standard sprint day. Grouped according to estimated lap time (0 time if you are new).
I would suggest putting your lap time on the form under modifications, if you are new to sandown put that down.
5-7 12minute session
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/#findComment-5775375
http://www.alfaclubvic.org.au/content/view/195/79/
They run a pace car that exists the track with the next group behind it as the last car from the previous group crosses the finish line and does their cool down lap.
https://www.sau.com.au/forums/topic/361664-ffcc-sandown/#findComment-5779759
    • Haha no I'll do that one tomorrow. I've been ignoring it. It's the 5.0 one I'm taking about. (There is a little X to hide the 4.7 one if you want)
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
