bubba Posted June 15, 2011 Share Posted June 15, 2011 Interesting, I have a couple of spare blue sensors at home.. when I get the 32 up and running I will swap a blue one in and see if it reads any differently. Link to comment https://www.sau.com.au/forums/topic/361767-coolant-temp-sensor/page/2/#findComment-5866570 Share on other sites More sharing options...
SargeRX8 Posted June 15, 2011 Share Posted June 15, 2011 (edited) My car also has the same issue as OP, when starting on cold start in mornings(stock ecu) the car will start to about 1krpm and then die if I do not blip the throttle for a split second. Something seems sticky... Its like something isn't opening up when it should be. I don't really understand the logic behind the water temp sensor causing the issue... If it was f**ked, a rev will not fix it. My temp gauge is working just fine so that gets ruled out I guess. When I get it tuned, ill get the tuner to check it over and clean any shit thats cleanable. Interestingly enough though, back when I was running a power FC it never did this. Always started perfectly. Going back to stock ecu(had stock, went pfc, now stock but going back to pfc soon), the problem came back. Edited June 15, 2011 by SargeRX8 Link to comment https://www.sau.com.au/forums/topic/361767-coolant-temp-sensor/page/2/#findComment-5866667 Share on other sites More sharing options...
bubba Posted June 15, 2011 Share Posted June 15, 2011 Temp gauge and ECU don't use the same sensor. Link to comment https://www.sau.com.au/forums/topic/361767-coolant-temp-sensor/page/2/#findComment-5866759 Share on other sites More sharing options...
SargeRX8 Posted June 16, 2011 Share Posted June 16, 2011 That is probably true. But I still don't understand how it could cause a startup issue but be resolved with just the blip of the throttle. Link to comment https://www.sau.com.au/forums/topic/361767-coolant-temp-sensor/page/2/#findComment-5868181 Share on other sites More sharing options...
bubba Posted June 16, 2011 Share Posted June 16, 2011 Probably? it is definitely true.. there are two separate sensors, one for ECU and one for gauge. Does it fix itself the instant you rev it? or are you giving it a few revs (and thus could be a time based thing)? If the ECU temp sensor is fkd, after a short while the ECU will just assume the engine is up to temp and normal driving can ensue. Link to comment https://www.sau.com.au/forums/topic/361767-coolant-temp-sensor/page/2/#findComment-5868257 Share on other sites More sharing options...
DJSimmo Posted June 20, 2011 Share Posted June 20, 2011 (edited) OP: is your R33 a Series 1.5 or Series 2? I have a red coolant temp sensor as well my part number on the sensor is.... A27-611 L00 This part number on the sensor does not seem to relate to any nissan part number in FAST but it does say JECS on the sensor and had the nissan symbol Edited June 20, 2011 by DJSimmo Link to comment https://www.sau.com.au/forums/topic/361767-coolant-temp-sensor/page/2/#findComment-5874280 Share on other sites More sharing options...
SiR_RB Posted June 20, 2011 Share Posted June 20, 2011 regarding the RB26, does the intake temp sensor (the one at the front of the intake manifold) connect to the ecu? if so could this also contribute to crap cold/hot starts? Link to comment https://www.sau.com.au/forums/topic/361767-coolant-temp-sensor/page/2/#findComment-5874459 Share on other sites More sharing options...
MatthewT85 Posted May 5, 2013 Share Posted May 5, 2013 (edited) i know this is years old, but does anyone else know for sure whats an option to replace the cts sensor in an r33 gtst? will this one work? http://www.ebay.com.au/itm/New-Genuine-INTERMOTOR-Nissan-Skyline-R33-GT-R-Coolant-Temperature-Sensor-/121056444459?pt=AU_Car_Parts_Accessories&hash=item1c2f86c02b its says nearly every other nissan except gtst also i am gonna ask the seller, just cant remember my login and password atm Edited May 5, 2013 by MatthewT85 Link to comment https://www.sau.com.au/forums/topic/361767-coolant-temp-sensor/page/2/#findComment-6839750 Share on other sites More sharing options...
Dan_J Posted May 6, 2013 Share Posted May 6, 2013 i've got a r31 rb30 tridon sensor in my rb20, pretty much all the same thing long as its connected up the right way Link to comment https://www.sau.com.au/forums/topic/361767-coolant-temp-sensor/page/2/#findComment-6840753 Share on other sites More sharing options...
