HKS 2530, trust T518Z, apexi AX53B70 - depends on what you call too laggy or nice power. Responsive, spool quickly and good for from 230-250rwkw, depending on mods and a large mid range increase.
HKS2835, probably good for around 270odd rwkw (depending on mods), little more laggy than stock, but not hugely so, also good mid range
A couple of ideas anyways:).
https://www.sau.com.au/forums/topic/36195-r33-turbo-upgrade/#findComment-721626
it's for David (white R33) .... nah he doesn't want something that big .... and he wants cheap as possible, as he isn't sure he is keeping the car much longer - he wants a GTR
https://www.sau.com.au/forums/topic/36195-r33-turbo-upgrade/#findComment-721818
hey nightcrawler....i just had my standard rb25 turbo rebuilt with t3/t4 internals and highflowed (have more power than standard and should have too much issues wif lag)....if ur mate is interested in that then pm me. i was going this option first but i seen something more desirable hehehe.
https://www.sau.com.au/forums/topic/36195-r33-turbo-upgrade/#findComment-722332
Hey dean, come for a ride now... Since porting the head It gulps air like nothing else, I can't get it to surge now at all, I am gradually bringing boost on earlier and earlier. My nitto's are wearing quick! (changing lanes is becoming a problem again) All I need is a Z32 A/F meter and I'm ready for a tune.
A 2535 is a perfect match for a RB25 in terms of Lag and power. Won't make much more than 250rwkw but will be a pleasure to drive in traffic. I think there is one for sale on the forum for $1500.... what's the price range you are looking for?
https://www.sau.com.au/forums/topic/36195-r33-turbo-upgrade/#findComment-738254
yeh matty, i will change the turbo soon, just gotta save up money for the rest, ie clutch.
So without the porting, what do u think u would of been making? Are u comin down to adel anytime soon?
The turbo works fine without porting. It is slightly laggy compared to other turbos 5 times the price.
I will be down in Adelaide soon ,but, without my wheels. you will have to come visit me in Syd. Autosaloon is a good excuse.
https://www.sau.com.au/forums/topic/36195-r33-turbo-upgrade/#findComment-738539
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
