black colour, MIVEC 2.0 V6 engine, 4 Speed Tiptronic, sony CD player/radio with 6 speakers, full electrics, central locking, immobiliser and alarm, tint windows. RWC include.
6,4000 kms, perfect condition. Locate in Melbourne.
$17,999 ono due to going overseas soon.
pls call Gene: 0421780241 (optus-prepaid) or send e-mail to: [email protected]. Pics can be view in my gallery. (Click the arrow under my avatar)
https://www.sau.com.au/forums/topic/36232-95-mitsubishi-fto-gpx-for-sale/
ok thanks mate. I am not back until the first week in July which is probably longer than you want to wait. It also wouldnt be a 100% definate buy without seeing and hearing it so I couldnt ask you to hold on to it. My mate has the Mivec here in dark blue so know a bit about them. I will keep my eyes on this section as I am on most days and if it is still for sale then, I will have a look.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
