Wrecking R33 skyline , Motor and box brakes comp and wiring loom and and Front Head lights and Front Bumber and Bonet sold.
What i have left is , Whole interior and windows , complete rear end , and passanger side , car is complete . has all wiring still intakd , passenger side back guard is good also can be removed if someone needs it , Airbags are not deployed it only has drivers side wheel air bag , dash is in good condition , whole interior is in good conditing beside drivers side door trim . cluster showing 177k on it .
Send me a message on 04170509090 , or PM will Post Pic s Later Today , Car located just out of Devonport. Can Post items Too.
Regards Broomhall.
https://www.sau.com.au/forums/topic/362598-wrecking-r33-skyline/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
