After reading that some people are getting fustrated at telling others that they shouldnt expect there n/a to be 100 times more powerful with basic modification's lets try and put one together with the help of everyone that explain why you do it what they do and what results should be felt or will happen to the engine....
how about
Part:
why:
Result:
and or Explaination:
https://www.sau.com.au/forums/topic/362638-na-modifications-explained/
Part :CAI plus air filter or pod
Why : to reduce the ammount of restriction the standard system has and to give the car colder air
Explaination: The standard system cardboard filter is quite restrictive (poor water through paper then through a siv)
with a phome filter or good pod the air can flow more freely into the induction pipes through afm ect ect
Problem : Pod without CAI or proper box will turn out worse Hot air is less dense and has less oxygen (i think)... (heat saturation)
Solution: CAI to deliver colder air to the now better flowing pod or filter
Result: Possible..... slight!.... gain in power but more importantly allowing the engine to recive colder air at a faster rate allowing it to breathe better changing its efficancy and response
Part : Extractors
Why: To help the exhaust "pulse" flow and the speed and rate the exhaust gas exits the car
Explaination: as the exhaust gas leaves each cylender we can now call this a pulse... on a standard system each pulse meets from each cylender along the pipe at the same place.
Result: extractors go 3 joints to 2 one joint to the end joint so this now pulls the pulses on the corrosponding cylenders down the pipes allowing them to escape better faster and in most cases louder :)
Car is now more efficant at removing the gases and will also deliver slighty higher results but again is more efficant
Part : Extractors
Thanks for the thread, I will now fill with my long and boring stories :)
On this
Good Headers/Extractors cost thousands, the ebay/other cheap ones are rubbish. If I ever get the time I will nut out a decent design for some and have a set made, because I am sick of seeing crap products being passed off as good.
Also Primary pipe length/size will vary depending on where you want peak torque/power, factory cams or aftermarket, Port work/valve sizes, whether you run mufflers or not, Exhaust pipe size and lenght all play a part in the design of the headers/extractors
So yeah, as an Eg, an old mate of mine who is an engineer has an XA falcon with a 383 cleveland that was putting out 430rwhp, It had a set of generic 1 7/8" 4 into 1 extractors.
We decided one day to nut out a new set with the aim of making bulk torque in the mid range to get the car off the line at the strip.
So many many beers (re: weeks) later we had the design (went shorter in the primary pipe length and increased the angle of the collector) he made them up at his shop, fitted them and went back to the dyno, the car picked up 10hp peak, but made 40 yes 40hp more at 4500rpm, just by changing the headers and altering the jets in the carb to suit.
gains from a CAI depend on how well the factory intake was designed. some cars benefit more than others.
Part : Extractors
there are different theories behind headers. for example, on a 4 cylinder some will run a 4-2-1 setup while others will run a 4-1 setup. length of the primaries and secondaries will determine where in the rev range the power comes in. primaries are the pipes immediately out of the head, secondaries are after the next join.
next comes the exhaust. a lot of people think bigger is better, and that is true to a point. others think you need back pressure and if you go too big the lack of back pressure is the reason why you can lose power by going too big. this is false. back pressure is bad in all exhaust systems, however sometimes you have to put up with it to get the power characteristics you want. if you want a car that is good on fuel, has plenty of pull in the lower rev range then you have to go a smaller exhaust. this will flow gases better at low rpm than a bigger exhaust due to a syphoning type effect that goes on. the downside is more restriction at high rpm. this is what the car manufactures base their exhausts off because on the highway, etc you aren't sitting at high rpm. if you put a bigger exhaust on you will lose a bit of low down power but gain high end power. this gain in the higher rev range often masks any loss in the lower rev range. if you go too big then you will lose even more low end power and it will become a slug for everyday use and might not gain any power up top. the same applies to extractors.
Camshafts -
Difficult topic but i'll do my best.
The job of the Cam(s) is to open and close the valves, they are the true power maker in a Natmo engine
Altering when the valves open and close has a marked effect on power/torque peak rpm etc
In simple terms, Production cams are designed with a broad torque curve and smooth delivery in mind, and are generally quite mild, with low lift and a short duration.
Now if we want more air to enter the combustion chamber we can do many things, we can increase the amount the valve lifts off the valve seat, we can lenghten the aamount of time the valve is open for (duration) and we can alter the cam timing (advance or retard)
Now I have never seen an aftermarket Cam that only increases lift or only increases duration, it is a combination of both that nets the best result.....
....But at a cost, larger cams require more RPM to work, and move the power band further up the rev range the more lift and more duration means the engine loses low speed efficiancy (no doubt you have all heard a lumpy idle on a hot rod or drag car) This in the case of very large race cams, requires stronger/lighter conrods/crank shafts/valve train etc that can withstand the higher RPM needed.
Larger cams also bleed off more cylinder pressure out the exhaust valves during the compression stroke (due to the valves being open for longer) So you effectivly lose compression (this is called dynamic compression) , so higher compression pistons are required to mantain the same dynamic compression ratio.
They also need modifications to the ports (commonly called port and polish) , there is no quicker way to kill the performace of a car than to stick huge cams in the motor and leave the ports and compression ratio as is.
So the heads need to be ported to match the cams, usually focusing on gas velocity (bigger ports are not always better, and in some cases the ports are filled with epoxy to make them smaller and therefore increase velocity)
I wont go into to how to choose a cam as there are too many variables.
But there are two different way to measure a Cams duration, there is Total duration, and duration a .050" lift, what that means is they count the duration from when the valve has actually lifted off the valve seat and can start flowing air.
All the Japanese cams are listed as Total duration, so while a 280degree cam sounds huge for a small motor (like an RB) the actual effective lift is closer to 235degrees depending one which brand of cam it is (some are more some are less)
I think I should also mention this - The more duration the further the powerband moves up the rev range, so you will often see something like this.
In - .513 236deg @ 050
Ext .530 240deg @ 050
^^ that there is a basic performance V8 camshaft (I just made it up btw) the duration as you can see is at .050" lift
and would give a 5L V8 good power upto around 6000rpm
Along side those details you will see something like
4000-6500
That is to give you an indication of where the powerband will be.
May also give info like
Rough idle, needs high compression pistons, 4000rpm stall or manual gearbox
Now if I saw something like that, I could make a choice, I would look at my current engine and think, "can it rev to 6500rpm without falling apart" "can I live with the rough idle and limited power below 4000rpm or do I need something smaller/larger" "Is my Stall converter large enough to get the car into the powerband at the drag strip?"
Things like that are what you need to think about, most street cars Dont need huge cams, just makes them a pig to drive and use heaps of fuel.
Also notice that in the cam specs they DO NOT give an estimated power or torque figure, that is because there are WAY too many variables to give an accurate figure.
I hope this helps.
Any questions let me know.
Andrew
cams simply open the valves longer and further than the stock ones, allowing more air and fuel into the engine.
head work increases the speed and volume of air that can enter the combustion chambers.
injectors allow more fuel to enter the combustion chamber. as you increase the amount of air that enters you need to increase the amount of fuel to keep the air fuel ratio right. petrol requires a certain amount of oxygen to get maximum bang. different fuels (alcohol fuels, etc) have different optimum levels.
damn, zebra keeps beating me to it (and with more details, lol)
do those Pon cams work with the n/a standard ecu like they claim to work thith the turbo one or is it differant ? is there a very small step one cam that will work a little bit better than standard ....with standard internals or once u step into cams u should always get head work done ?
i'm going to go a little bit different now. suspension.
everyone thinks lower, stiffer suspension is better. this isn't always the case. lower is better because it lowers the centre of gravity, reducing body roll and keeping weight more even across the tyres, thus giving you more grip. stiffer suspension also aids in this. there is a limit to how stiff is good. on a rough road then super stiff suspension will give you less grip than a softer suspension as the stiff suspension will cause the car to skip over the bumps rather than absorb them, but on a super smooth road then you can go a bit stiffer. stiff suspension does put more strain on other parts of the car though. things like engine mounts, gearbox mounts, etc will all wear out faster because they are getting more stressed. in the case of drag cars though, softer suspension (at least in the rear) is a benefit because you get more weight transfer to the rear of the car and more weight over the rear tyres then the less wheelspin you will get. stiff suspension on a car will actually make it harder to get off the line cleanly, so if you ever see a car setup for drift at the drags you will usually see pretty crappy 60ft times from them compared to a car with stock suspension.
unlike aftermarket ecu's, most stock ecu's will adapt to simple mods as they have a fair bit of headroom above where they are running standard. aftermarket ecu's are tuned specifically for the car and are generally running closer to the limit (hence why they put out more power than the stock). that said, if you do make a change to something like cams then the gains you get from the individual mod will be greater with the aftermarket ecu since it can be tuned to make the most of the mod rather than simply adapting to it the best it can.
http://www.cranecams.com/268-269.pdf
This is one of the best cam catalogues I could find relating to Import performace motors, You can see what I was talking about regarding what the cams require.
There is other info in there, Such as lobe separation angles etc, I deliberatley left that out, but I will touch on it briefly
the Lobe separation Angle or LSA is the angle between the Intake and exhaust lobe (which is the lumpy bit on the cam that makes the valves open)
This can be altered on RB engines by the use of adjustable cam gears (which is why I didnt mention it) But plays a bit part of older Engine cam engines (eg Rb30 or American V8s)
But the closer the angle eg 110degrees in the case of the EVO motor above means the engine will produce more top end power than say having them set at 114degrees.
It is effectivly the amount the valves overlap, eg the intake valve opening while still on the exhaust stroke, or vice versa, and you can see that info where it says
Open/Close
@ .050”
Valve Lift
Int/Exh
That tells you when in the 4 stroke cycle the vavles are open or closed.
hmmm $880 dollars for poncams ? worth it for the results with the standard system ?
In short no, the car will run yes, but wont net any real gains without a decent exhaust at the very least.
Also Cams for turbo engines differ greatly to NA engines. So while you can have a 260deg 8.8mm lift cam for a turbo engine and an NA engine, things like the LSA and the ramp rate of the cam lobe are quite different.
So while the Poncams etc would work ok, there would be better results had by getting a custom set done specificly for your NA engine.
does a lower car also have a better or worse aero dynamic efficancy ?
would very much depend on the car. what most people think of when thinking about aero effeciency is the front of the car, however it is often the rear of the car that makes the biggest difference. for example, back in the late 80's and early 90's volvo racing cars were wagons as they were better aerodynamically than the sedans, despite having the same front end. a lot of cars actually get a big swirling vortex at the rear of them which creates a low pressure area behind them. this actually sucks them backwards a bit. anyone who has driven a station wagon or hatchback in the rain will see how much spray from the tyres ends up on the rear window. if you look at the back of a lot of wagons you will see a little spoiler type thing that directs air downwards (my vt wagon has one). this helps to reduce the vortex, or at least move it further back from the car to reduce its affect.
this vortex does have 1 advantage though. if you happen to be able to get behind a truck on a bike then you can really get some speed up without much effort.
Depends on what you mean by "Aero dynamic efficiency" and on what car you are talking and what you mean by "a lower" car.
Will lowering your stock GTS Skyline 1" off the ground make it handle awesome? No.
Part: Splitfire , super spark . yellow jacket ..... coil pack
why : standard coil packs burn out ... they work in extremely hot conditions and with really high ammounts of electricity
burn out means eventual engine light and horrid missfire usualy in the conditions late at night in the rain and no were near a work shop :P becasue the spark is not going were it should
results : desputeable gain but more importantly relyability :) and not having to baby your car home couffing farting spluttering and carrying on
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
