hey ppl currently building my rb25 just wanted to know how much the rods can take? im thinking of getting them shot pind ect will it be wroth it or just save up for a set of spool rods, im hoping to build a power house of a motor gona run big boost
any help will be great
thank you
https://www.sau.com.au/forums/topic/362840-rb25det-con-rods/
my old built 25 in the VL was making 350kw and when the engine was pulled down it had 3 bent rods. it only had a fresh set of bolts fitted so im very lucky to not have thrown one.
rb26 ones are a lot stronger than 25's so if cheap upgrade is what you are after they may suit.
yer tryin to b a cheap kent lol... if they can take the power then y change em
im aimin for 400rwkw around that mark prob 20-30psi
GTR rods if you want to be a tight arse, $150 for the 6 and will do the job, need pistons to suit
yer jus usin the 25 crank so 26 rods should b fine?
RB25 and RB26 Rods are the same length, the difference is in the Pistons - gudeon pin is a slightly different height on the piston as the piston deck height is different.
Thats only due to the 26 having a longer stroke...makes ZERO difference when using the 25 crank.
Unless of course you're saying not to use 26 pistons?
If you are ignore me lol
I am only saying the rods are the same length :thumbsup:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
