Hi everyone,
Sick of that stupid bubble on the passenger side of your R32?
Then get this dash!
Going cheap at $100.
Will be hard to find another like this, no cracks or holes in the vinyl either but there is a small raise just on the console part.
https://www.sau.com.au/forums/topic/362846-r32-gtr-or-gtst-dash/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
