hey guys,
my car is a manual S2 (narrower track in the rear).
i'm looking at ordering new rims and am tossing up between
19x9.5 (+22) all round
or
19x8.5 (+22) front, 19X9.5 (+22) rear (wider in the rear to compensate for the narrower track).
can anyone foresee any probs? tyres front and rear will be 235/35/19 (as i have them already). will rolling diamater be affected much from the extra stretch on the 9.5 rears over the 8.5 fronts?
https://www.sau.com.au/forums/topic/362910-wheel-fitment-for-rs4-s/
hey guys,
or
I run 19x9.5 +12 all round
The rears are flush at 320mm ride height and 245/35/19 tyres are a bit stretched. The rims are wider than the tyre, so the cloest thing to the shocks. No rear guard rolling needed on my car. Clears by 3-4mm
The +22 wheels you are looking at will run very close to rear shocks being 10mm further in than my car
You may need to check this before you fit the tyres
The fronts should sit pretty flush. As I have the R34 front, the guards a approx 25-30mm wider than stagea ones.
so darrin, perhaps a 10mm slip on spacer for the rear and everything will be ace?
10mm worst case. You may need to fit longer wheels studs, so more cost
You maybe ok without one or maybe just a 5mm
Also depends on what brand of shock as the diameter can vary. I have Bilstiens in mine
auto series1 wont help as it has wider rear track. i have 18x8 with a 34+, they sit in abit, standard kind of offset. the front is about 10mm of perfect flush and the rear is about 20-25mm but its hard to judge with 2'45 degrees of camber in the rear.
i rekon your second option is good but you need a lower offset in the rear personally, fella i got my coilovers off has a 15mm bolt on spacer on the rear of his 260RS for 17x9s.
or buy you first option and throw a 10mm hubcentric spacer at the rear
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
