Genuine Greddy Alloy Pulley kit suit R32 GTR
Includes Water pump, Power Steering and alternator pulley as well as the alternator fittings and instructions
Brand new and includes Express Post Shipping within Oz
Wont fit 33/34 gtr
Translated text from the greddy website
Weight by a pulley, reduces rotational inertia of the engine shaft, the better the response. Duralumin (A2017) made of anodized blue. Belt supports genuine. Water Pump, Pawasuteponpu, alternators, for there are ハイドロリックモーターベーンポンプ.
Large diameter aluminum GReddy Pulley Kit
Stock lasts ※, will be discontinued.
The large-diameter aluminum pulley RB26DETT engine only. The design for the ratio of each rotation of the pulley, high speed specification (9000rpm) engine support. The larger and lighter pulley, greatly reducing friction. Response is improved, the power and torque boost. In addition, since the increased bearing area of ​​the belt prevents belt slip even at high rpm.
Cooling water to prevent cavitation at high speeds, is also effective in preventing overheating. Reduce the burden of the alternator at high speeds, ensuring enough charge at low rpm.
Duralumin (A2017) made of anodized blue. Water Pump, Pawasuteponpu, alternators, for there are ハイドロリックモーターベーンポンプ. Fan belt only reinforced durable, and comes with Pawasuteberuto. A large diameter pulley kit installation requires turning the crank pulley.
    • It's been quite the ordeal but hey, at least you figured it out.
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
