Hi guys,
Long story short i want to remove my hicas as its playing up.. Now i have been told a few conflicating storys on what to do/not do by a few workshops one said i MUST use a 33gtr power steering pump or remove half of the veins on the impeller on the 32 power steering pump otherwise it will over pressurerise the steering rack and cause the steering rack to leak?? Others have said no drama's just pull it out and put a lock bar in it makes no difference and another said that you have to re-wire the hicas to stop the hicas light coming on and not to use a lock bar but get the standard rack welded up so you dont have to remove the lines etc..
Could someone that has removed there hicas please shed some light on this and point me in the right direction? Any help is much appreciated
https://www.sau.com.au/forums/topic/363086-r32-gtr-hicas/
Here is good guide: http://www.nissansilvia.com/forums/index.php?showtopic=185697
Put in a lockbar, then you bypass the front Hicas solenoid by looping (through the power steering cooler) the rear stage of the pump.
You DON't need to remove the vanes from the pump's rear section
Getting rid of all the hicas gear saves ~20kgs. The light on the dash is fixed by cutting a wire on the hicas ecu.
My r32 has been like this for over 2yrs with no problems.
https://www.sau.com.au/forums/topic/363086-r32-gtr-hicas/#findComment-5794427
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
