same as last time people (run through arron magill(automotion) and ask anyone that came to the first day it was a ball)
1st may
this is a drift driver training day people( non competative)
Passengers $30
once again its the entire north circuit of oran park north
so there will be multiple track configurations and tonnes of skid time
instructors will be available for the newby and this will be a great environment to learn and have a great time
usual story deposit gets you in. numbers are limited to 30 with 5 reserves
what do you get for your 150 +15gst(sorry people gst has been added) bux............
full day tyre frying
instruction
fully catered lunch
respect from the crowd
and a video(people at fatz drift day 1 i havent forgot yours is comming)
any questions dont hesitate to call me
pete
0409226626
Entrants:
1 me (looking for a pinny wagon to drift people after i smashed my silvia)
2 Mark D deposit $50
3 Chris Deposit $50
4 Kyle Payed $150
5 My Bro $150
6 Manganal
7 Matt Nugent $50
8 Ben Ellis $50
9 Daniel Forrest $50
10 Van der Wagon $50
11 B-man Paid
12 ben Harwood $50
13 Paul lx Torrie paid
14 Aaron 180sx paid
15 Andrew vxss paid
16 alexi
17 adam vl paid
18 luke paid
19 tex gemini paid
20 mick cain
21 carvey $50
22 nick soarer paid
23
24
25
26
27
28
29
30
https://www.sau.com.au/forums/topic/36317-fatz-drift-day-2-sat-may-1st/
  • Replies 248
Dudes Tyres is not a problem if you have trouble finding a pair go to Milperra Tyres he will sell what you need half worn quater worn worth the phone call if you cant get any for free....... hes in bullecourt ave P.S. just so as you all know Milperra is Aboriginal for "a good place to camp" HA sometimes i amuse my self.
Diff in (don't know if I like it though... might just need to learn how to drive it? Sux BAD at low speeds) Suspension in and aligned. Tune engine and I think I'm ready to go!
Pete I'll flick you a deposit next week!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
