R33 Engine Problems
chrischen
 Share
my r33 gtst is un happy at the moment. the second water related hose has let go within a month. i am almost up for a timing belt,water pump change and she is due a service and tune. on the way home today after replacing the water line at the rear of the engine i was loosing power under boost, the revs where fluttering up and down and there is a groaning type noise . i also noticed that the vacuum section of the boost gage was registering lower than i have ever seen. is this miss firing spark related and can anyone shed some light on these problems thanks
might be worth checking the oil and coolant. make sure neither are milky. also look at the coolant with the engine running. if there are any signs of bubbles then you may have a blown head gasket (also if you are losing coolant).
Did the engine overheat at all?
Did u bleed the colling system after u replaced the blown hose?
Is the problem always there or intermittant?
engine didn't over heat i had only driven a short distance and realised something was wrong
the colling was not bleed but there is a fair bit of rusty looking residue where the hose has sprayed in the engine bay
the problem is intermittent but its only just started happening.
when the first hose went i thought i may be up for a head gasket but got lucky when it was found to be a split under side radiator hose. all the hoses are a bit crusty getting on now.
any idea ?
there is no milky looking stuff, radiator could do with a good flush. hope im not up for a head gasket as well as the rest of the things that need attention.
 Share
    • Oofftttt… I remember when I bought genuine ones for $500 delivered from Japan
    • no probs I got 1 maybe 2 coming with me atm ...   yeop hopefully advance in times and all that - fingers crossed - just looking to push and get better - tis all we can do its have a go right
    • Came across these Ganador reps and am wondering if anyone has used these/come across these ?  Seem to look like reasonably good replicas (shape wise) from what I can see. Ive been told by them that they are moulded to be exact copies of original Ganadors (but thats what every replica version will say) https://www.shiftperformance.com.au/ganador-style-mirrors-suits-nissan-skyline-r33-gtr Photos of them installed appreciated Thanks 👍
    • lol, yeah, and how gutted I am now I’m back over in Europe (actual Europe) and dealing with the nightmare of U.K.-Continental Europe bureaucracy.   Anyway, arrived in NL early January with the BMW, whilst the Skyline followed suit about a week later. Both cars ended up stuck with their relative importers for about six weeks. Since then, I made a trip to the Nurburgring with a friend and have since ditched the Skyline in the garage. This week, I finally managed to find a suitable shop to do an alignment so hopped on over to Germany to fix the miserable mess the local Netherlands shop conducted; the car was just not aggressive enough in the rear for my driving style - I found myself understeering a fair bit at the ring which was really a first for me with this car. Mis-matched F&R tyres can be held partly responsible - have now moved to F+R NS2Rs. One thing I’ve noticed is the 180kph limiter just does not cut it here. I quickly hit that (for the first time) in Germany on the autobahn. Japanese circuits are small - at least the ones that were near me. I rarely spent much time in 4th. After much deliberation with the HKS SLD, I have ordered Nistune from Matt. Whilst the Skyline has been gathering dust I got to learning the highly neglected BMW I bought in the U.K. was in fact just that, highly neglected. Took the ol’ dog down to Switzerland last weekend with a progressively deteriorating front end. It went from vibration during braking at highway speed on the way down, to vibrating non-stop on the way back. I’ve already fixed numerous engine issues - low oil pressure, f**ked injectors, incorrect coils and plugs, electric water pump. Still to do is a suspension and brake overhaul, rear subframe replacement and likely more ageing engine electrical components. But I must say, I love it. After so long with the Skyline, I really didn’t know cars could be so comfortable.
    • Thanks. I adjusted my soft cut to 7600rpm and if I see I'm still making power there, I'll consider readjusting to possibly 7800rpm while on the dyno.
