Ive had a look at the trnsparent plastic doofa, both lugs are snapped off, in was glued in but the top is intact
I couldn't find any type of rubber in the area you've described, post up a pic
same with you're wind deflectors, do you mean monsoons? if so it doesn't have them but put a pic up
those plastic clips are missing from this car and mine but I used some aftermarket wurth ones instead
and I love your ride thats a minter!
The lugs were snapped off mine too, but the whole thing went missing when my windscreen was replaced, so even a glued one would be an improvement.
I don't have the bit of rubber either, but there's an obvious prong on the back of the arm for the mirror where it should be. S13s have the same thing only it's about 2mm too short.
The wind deflectors are OEM as far as I can tell
Guess the only bit I can get from you then is that silly bit of plastic.
I realise I'm probably being a bit OCD wanting these but I want to try and keep this car tidy looking.
  • 1 month later...
