Very quick brief. Heater core failed last year, replaced it with a new one. 100kms later the radiator springs a bad leak, replaced it with a new one. Bought a nice new SPAC radiator cap. Flushed the system over and over. Filled with Nulon concentrate and de-mineralized water. Fingers crossed thinking all was good.... it's not :(
At first I thought I just hadn't bled the system well enough, even though I was meticulous in doing it the first time, then did it again just to be sure I wasn't nuts.
What's happening is the overflow bottle keeps draining. But the real scare is the coolant is dropping in the radiator itself. I don't see a leak at the bottle, rather I think the radiator is sucking the overflow into the system as intended when the levels get low. But it's happening slowly. So slow in fact it never leaves a trace like puddles or visible places where I can see water. Slow enough you can do hundreds of kms and not notice any difference. But fast enough that you could be in real trouble if you don't check the coolant after a few weeks.
What to do? Get a pressure test? Have I got more serious problems here? Or could it be something more benign like a micro crack in a hose?
https://www.sau.com.au/forums/topic/363668-losing-coolant-again/
Went to get a pressure test done today, and it took the radiator guy all of 5secs to determine my water pump is on it's way out. Oh joy. Do people replace this and do the timing belt themselves? or is this a case of paying to get it done properly. I know I could replace the water pump part, but the timing belt part I wouldn't have a clue.
hey man thats not good to hear. but at least you found out sooner rather than later. When i got my pump and timing belt replaced i opted to pay someone else as I didn't feel comfortable attempting it myself. I think it ended up costing around the $400 mark but saved me a lot of hassle. Each to there own though. let us know how it goes or if you need a hand with something
Sure thing Ty. I had a look on ebay for a water pump and someone is selling a brand new oem aftermarket one with timing belt for about $140. Not bad. Obviously there's labour to be tacked ontop of that. Do you remember who did yours for $400?
While your pump is out, you might want to replace all the stuff for the 100,000km (timing belt, bearings, seals) service if they haven't being done already.
Get a kit like this and just pay a decent workshop to change it.
I had similar experience with my cooling system & the forever patching/fixing stuff up...
In short:
Slightly overheated, replace thermostat & Rad Cap = problem fixed.
2 weeks later, plastic top tank cracked; got that replaced.
1 week later, water pump found leaking; replaced that, along with bearings & belts.
1 week later, o-ring around plastic tank leaked, got that repaired.
So basically 4 problems one after the other in like 1 month... LOL
Its possible to do yourself if your confident in your mechanical skillzzz.. the difficult part is pulling of the harmonic balancer gruuuh! It is FAR easier on a hoist too.
I did my "100,000K service" in mine at 70,000, because i had a really noisy tensioner. It took my 6 hours to do >_< mainly because i couldnt get the crank pulley off, and then couldnt get the CAS back on LOL.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
