Hi,
Can anyone point me in the right direction for a radiator fan shroud that sits ontop of an aftermarket radiator like the picture attached. The OEM shouds do not work as they are bolted to the standard radiators - ofcourse aftermarket radiators do not have these bolt locations - well atleast my ARC radiator does not.
See pic attached
Edited by Buildn
https://www.sau.com.au/forums/topic/363827-r34-gtr-fan-shroud/
Hi mate, any reasonable quality radiator should have mounts for the factory shroud - it just requires a small welded fitting in 3-4 spots.
If not, you may be able to hold the factory shroud in place with cable ties. Small ties will fit through the gaps in the fins if necessary
