gday fellas! hope your weekend is off to a flying start :)
just halfway through converting the front of my C210 to S13 coilovers and knuckles. the silvia lower control arms are too short and give the car a very aggressive positive camber!!
just wondering if you guys could measure yours over the weekend for me? lets go with from the hole where you bolt it to the car to the pin that goes in the knuckle.
https://www.sau.com.au/forums/topic/364230-need-some-lca-lengths/
Let me know how it goes ey, cause i want coilovers in mine so much more handling with stiff suspension lol
have a look in my build thread. in a recent post i show how easy it is to make s13 ones work in the rear. when i figure out the recipe for the fronts i will be letting everyone know dont worry.
s14 are 15mm longer then s13
r31 are shorter then s13
r30 is longer then s13, not sure how much tho as mine have been modifed to adjust track/camber. i can measure some stock ones when i get around to the other shed.
r33 use different ball joint to s13 but are 15mm longer too im pretty sure, can just press out ball joint to change tho.
so im thinking either s14 or r30 lca, s13 knuckles/hubs/brake, can't use stock s13 struts because the spring od is too big for c210 strut tunnel so have to use coilovers.
what tie rods are you planing on using or will stock ones work?
cheers for the info mate!
well im using the s13 coilovers, knuckles, hubs and brakes that already have sumitomo calipers fitted which is the bonus. ill see if i can borrow an s14 LCA for a test fit.
if i cant find one long enough, im going to have to buy adjustable ones so i can wind it right out.
once i get the LCA sorted ill be able to tell if the tie rods can be adjusted to the right length or not. the tie rod ends look the same on both C210 and s13 so compatibility with the knuckle shouldnt be an issue.
i have adjustable castor arms from the s13 as well. as where the C210 castor arm blots to the LCA is different, im going to have to cut the C210 one in half and tap a thread on the end of the bit that bolts to the car. then remove the car end of the s13 one and screw the modded datsun half into it. does that make sense? lol.
thanks again Gordie.
i have seen adaptors somewhere to bolt onto the s13 castor arm at the bush end to make them fit the stock body bracket, might of been on a ae86 as the have similar set up.
other wise r31 castor arms bolt up to s13/14 lca's so mabye some adj r31 ones might be the go?
what swaybar set up will you run? my mate has a s13 one in his c110 so should fit c210, he just needed to modify the links slightly.
you'll be running those 18's in the pic in the other thread? pretty sure 15's are min for s13 brakes if anyone else was planning on doing the converion.
are you saying a S13 will fit a KHGC110 or a HGC110 ?
What thickness is it (standard or aftermarket ), since I know nothing about these later cars, is it from a 180SX / 200SX or are the same ?
I'm looking for a thicker one for my coupe
Nigel
Edited by noddle
Nigel
Tom has one on his green coupe, we'll im 99% sure thats what he put on, it was either that or a r31 one. he just needed to change the swaybar links a little.
i think s13 bars are 20mm
If your after a even bigger one then r32 gtr ones (25mm i tihnk) are used to upgrade in s13's so you'd think they would fit to.
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
