hey guys this is my first post and i have a few plans,
i want to put a 6 speed gearbox in my gts and need to find one that wont be a pain in the ass with the size and/or fitting
i understand ill need to get an adapter plate made up and tailshaft and info on what gearbox to use and general help would be great thanks,
https://www.sau.com.au/forums/topic/364356-r33-6-speed/
  • Replies 86
and i was thinking twin high flowed rb26 turbo setup
550 cc injectors, tomie poncams, cam gears,
anyone think of anything to build an awesome engine
Im building an rb30/25 (about 40 percent done, engine runs pretty good but gutless still stock n/a ,atm, now its time for the mods.
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813771
Dude i think you will probably find its more bother than its worth.. in my experience these sorts of things tend to turn out costing more than the car itself. Is there a specific reason you wanted to go 6 speed?
what mods have you done to your gts-t, thanks
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813801
what about a r34 gtr box with the transfer box removed (if it's possible) or just with the front drive shaft removed
Same as the 350Z box but with a different Bell housing, so same deal really, eeither cut the transfer case off the GTR box or make a bell housing adapter for the 350Z box...which I belive Mark @ Hills motorsport in Castle Hill were developing a kit do do exactly that.
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813820
Im only starting brother, its pretty stock at the moment- turbo back zorst, coil overs, intake, R34smic and a slight boost increase. I plan on a hiflow turbo, upgraded injectors and front mount soon. I will be happy with around 250rwkw.
Your 25/30 build sounds f**king promising though! I think the whole idea of the 6 speed is great in theory, but probably way too costly to make it worth it. Definitely worth looking around at it though and getting some prices, i always wish my liner had an extra gear on the highway.
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813856
thanks man, down the line when im finished the engine ill probably go all out with the 6 speed gearbox,
but atm ,
im up to getting the mods (in progress) and fitting them, tuning it, work out all the kinks, lay down some 1/4 mile times, hopefully some track runs
and then worry about cruising down the highway in six ,haha, would be sweet though.
cheers.
https://www.sau.com.au/forums/topic/364356-r33-6-speed/#findComment-5813920
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
